It is currently Fri May 24, 2013 2:12 pm
 Post subject: Backup - Raid ?
PostPosted: Fri Oct 05, 2007 1:48 pm
Hi
I read with interest Gordon feature Backup your digital photos part 2, continued
I have a question on hardware based Raid Controller card - what happens if the card dies ? Do you essentially loose all data, though all the disk are still fine or can you recover these data by getting the same card ? or will other card do as well ?
Anyone can help ?
Thanks
DavidL
PostPosted: Fri Oct 05, 2007 9:46 pm
Hi David, good point. If the card dies, then yes, you will need an identical - or compatible - replacement controller to get your data off the disks. That's the downside to RAID, but compatible controllers are normally relatively easy to find - just go for a big manufacturer like Promise or Adaptec in the first place.
But if you're also keeping a backup copy offsite, it shouldn't matter. I have a duplicate on a single disk I keep elsewhere, so that will work on any IDE controller...
PostPosted: Fri Oct 05, 2007 10:41 pm
Thanks Gordon
Much clearer now and also seems to add more $ to the cost of this hobby !
I will need to KIV this for later and will keep an eye out for RAID cards.
One more question
Is RAID controllers only for SCSI hard disk ?
or Do they have it also for IDE or SATA ?
PostPosted: Sat Oct 06, 2007 4:51 am
You can get them in all flavours. I'd prefer SATA2.
PostPosted: Sat Oct 06, 2007 6:21 am
Yep, they do RAID for all types of HD interfaces, but SATA is the most popular and sensible right now. Have a look at the other threads in this section about RAID as there's some info about the different levels etc... for example RAID 5 is great, but if the card uses a software solution it's very slow for writing.
PostPosted: Thu Oct 11, 2007 8:11 pm
SCSI!!!
SCSI Fiber Chanel Raid!!!
Or to be more sensible - SCSI 15,000 RPM Ultra Wide 320!
We use them in severs, they are super fast and I don't think one has failed on us yet.
Seriously though, SATA or SATA 2 will do fine in Raid 1 or Raid 5.
MY FLICKR!
 Post subject: RAID or External
PostPosted: Thu Oct 11, 2007 9:51 pm
Hi David,
While I am a fan of RAID (I have a RAID 5 array of four disks on my big machine) I don't regard it as a total backup solution. The reason is that while you are protected against a single disk failure you are not protected against the admittedly unlikely event of your power supply failing in such a way as to spike power into the PC thus frying the components.
A Network Attached Storage (NAS) device is another possibility. They are getting relatively cheap these days and can act as media servers as well. While they are not completely electrically isolated from the main PC they are as good as but are still likely to be vulnerable to that dreaded house fire.
I would recommend you look at either online storage (have a look at the Amazon Simple Storage Service for example which at $0.15 per gigabyte per month plus a small fee for data transfers is pretty cheap). Or you could use an external hard drive (USB2 or Firewire 800) and, if you can run to it, a small fire safe which is useful for other things as well!
It all depends how much you value your data. Paranoia is a good thing. :wink:
PostPosted: Fri Oct 12, 2007 1:10 am
Thanks all.
I have thought about
DD_nVidia wrote:
SCSI!!!
As much as I like SCSI - I can't afford it. Too costly here.
As for RAID - I'm ashamed to say, none of the local computer stores carries one (RAID Controllers) - reason - no demand - but they can do a back to back order with 50% deposit up-front ! :cry: Not cheap though.
Yeah - I thought about this as well. Relatively cheaper than the 2 better and quality options above - I just need the storage enclosure , get a couple of hard disk and CAT5 to network them!
Thanks for all the tips and advice - But due to cost - I have decided to do
backup 1 - via external USB hard disk
backup 2 - burn a copy to DVDs
Of course - should a fire starts - hopefully not ! - then I need to get Paranoid
I'll check out the Amazon storage too !
Thanks everyone for your time.
DavidL
PostPosted: Fri Oct 12, 2007 1:23 am
Hey Bob, connecting a UPS in-line will prevent any problems caused by either total power cuts or "brown" (?) electricity. I've used one for the last 3 years and it's very unobtrusive. My one conditions the electricity too and it's amazing once you have one connected to see just how irregular the average power supply to the house can be.
Once we did have a complete blackout. As my wife sat staring at the blacked-out telly she turned to look at me happily gaming away and just shook her head. I like to think she was jealous, lol.
Zorro 8)
PostPosted: Fri Oct 12, 2007 10:21 am
Good choice IMO 8)
zorro wrote:
...connecting a UPS in-line will prevent any problems...
I agree. Being a country boy with occasional power cuts I have four scattered around. They do protect against most mains surges but, obviously, don't protect against the scenario I was considering where the PC power supply unit falls over and loses voltage regulation.
PostPosted: Fri Oct 12, 2007 6:45 pm
Most boards have some type of raid controller on the board.
I can have Raid 0,1,2 or 5 on mine (I think there are others but you get the idea)
Most boards with 4 or more SATA connectors have some type of RAID system on the board south bridge controller its self.
MY FLICKR!
PostPosted: Mon Dec 10, 2007 11:22 pm
Bob what UPS or SPS do you use? I use the excellent Powerware 5125.
Not cheap but it has never failed my system.
Canon EOS 40D, Canon EF 24-70 F/2.8L USM, Canon SL 580 EX Mark II, Canon Battery Flash Unit CP-E4, Canon BG-E2N (Battery Grip), Canon Right Angle Finder C, B+W 77mm Kaeseman CP (MRC) Filter, B+W 77mm UV Haze 010 (MRC) Filter, Canon Timer RC TC-80N3, etc.
PostPosted: Tue Dec 11, 2007 2:30 am
G wrote:
Bob what UPS or SPS do you use?...
I have a total of 4 APC units dedicated to various tasks. The monster is the SmartUPS 1500.
PostPosted: Tue Dec 11, 2007 4:55 am
This is mine and it is sweet 5125 1500AV.
http://www.powerware.com/EMEA/UPS/5125_specs.asp
It's good practice to have one or more. The other one I want to rig up to my plasma TV and multimedia centre - I'II do it today. I don’t think "her in doors" is gong to like that down stair in the front room.
It weighs in at 25K.
We don’t get many power cuts in Kent but it keeps the line clean.
Did you know Bob that we get more that 240V in the UK, more like 258V? They switch over stations at about four, so that’s the reason for the lights dimming momentarily.
Reassuring that my system never suffers and runs from the in-line SPS at 220V.
As an IT technical I always press upon clients to get a high-quality but cheap SPS or UPS at about £58. Normally, APS or Belkin. But they never do.
