It is currently Wed Jun 19, 2013 12:35 am
PostPosted: Fri Jun 15, 2007 11:16 am
Hello!
I received some great help from a person
but dont want to burden them with being too needing :P
I have a DMC-FZ50 and dont know how to tell which lenses will attach.
They recommended me the DCR-250 and am leaning this route so far.
I am looking for the best macro shot I can.
Not too concerened about cost.
I have seen pictures from a D50 with a Sigma 105mm Macro
and want to try to get at close to those results I can.
My questions are
How can I tell which lenses will attach to my FZ50
and
will either of these lenses work and if so which is better
55mm f2.8 Macro Lens Pentax K-A/R 1:1
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... &rd=1&rd=1
Vivitar Series 1 105mm Telephoto Macro Lens Pentax
If posting the eBay links violates rules PLMK
and I will not do it again! sorry :(
Thank you for the help!
Karl K.
JzmDjnn
PostPosted: Sun Jun 17, 2007 12:23 pm
Forget about both macro-lenses that you linked to!! These can not be put in front of the Pana-lens!!! :cry:
If you want to get closer you need something that is called "close-up lens" - nothing else. And you need one that has a standard thread of 55mm diameter.
The major thing to look after here is that a "camera lens" is not equal to a "close-up lens". A camera-lens has to be attached to your cam-body, whereas a close-up lens has to be attached to the front thread of your camera lens you already have. The Pana FZ-50 does not have a interchangeable lens - so you can only attach a close-up lens :idea:
The strenght of close-up lenses is measured in diopters or mm of focal length. The higher the diopters or the shorter (smaller) the focal lennght is the closer you can go with the lens.
The official add-on close-up lens for your Pana is the DMW-LC55E. I cannot find technical data but assume that this one has a focal length of 550mm. So if you zoom the FZ-50 out to the max you can focus at 40-50cm distanc. That should give you some additional magnification on that cam, as with the tele, you get only as close as 200cm. So my assumption is that this close-up lens gives you 4 times the magnification than you would normally get in your tele-zoom position. But you can use any close-up lens as long as it has the 55mm filter-thread. Canon makes some pretty good ones!
One last advice: As the built in camera lens "looks through" the close-up lens every quality problem of the close-up lens is magnified buy the camera lens. So it is advisable to buy a good quality cose-up lens, not a cheapo for 15 EUR/$. I once did this and immediately sent the close-up lens back...
