It is currently Fri May 24, 2013 11:41 pm
 Post subject: Too Much Yellow
PostPosted: Mon May 07, 2012 7:30 pm
I have a Lumix G3 with the 14-42 mm kit lens. I am getting green showing up with a yellow tint or bias. Grass and leaves look yellowish green rather than green green. If I take the photos in raw format and convert to jpg using the default settings, the color looks about right.
I would appreciate any advice on what causes the yellowish tint and how to get rid of it.
Thanks, Jim
 Post subject: Re: Too Much Yellow
PostPosted: Tue May 08, 2012 1:30 am
For starters, I'd set your white balance to "auto"
Trevor Harris
Nikon D200
SB-600
YN-560 II
YN RF 603 x 4
Tamron 17-50mm f/2.8
Nikon 50mm f/1.8
PostPosted: Tue May 08, 2012 4:49 pm
Thanks for your reply. The White Balance is set to auto. Maybe I need to make a manual adjustment?
Thanks, Jim
PostPosted: Wed May 09, 2012 12:08 am
Mind posting the photo so I can have a look at it?
Trevor Harris
Nikon D200
SB-600
YN-560 II
YN RF 603 x 4
Nikon 50mm f/1.8
PostPosted: Wed May 09, 2012 1:33 am
OK, will do tomorrow.
Thanks, Jim
PostPosted: Wed May 09, 2012 5:15 am
When you're setting the White Balance--i.e. after you've pressed the WB button--you can adjust it by touching the bar that runs along the bottom of the screen or by scrolling/turning the wheel/dial. But this only adjusts red/blue. So you may also want to try setting a custom WB (with a blank piece of paper). Or setting the temperature (in degrees K).
PostPosted: Wed May 09, 2012 4:36 pm
Well, I don't see how to attach a photo to a post. I don't have any on-line photo album. Any suggestions?
Jim
PostPosted: Wed May 09, 2012 7:55 pm
Here is an attempt to show one of my photos.
http://i1076.photobucket.com/albums/w45 ... 010017.jpg
Regards, Jim
PostPosted: Wed May 09, 2012 8:14 pm
Another attempt to show a photo.
PostPosted: Wed May 09, 2012 8:19 pm
Another attempt. (Sorry)
PostPosted: Wed May 09, 2012 8:54 pm
OK, here are two photos. P1010236.jpg is as taken. P1010236_1.jpg was taken raw and developed with Panasonic SilkyPix Developer.
I think the as taken has too much yellow and the developed raw looks normal.
The photo above is "as taken".
The photo above was taken raw and developed.
I would appreciate any insight about the colors in the two photos.
Thanks, Jim
PostPosted: Thu May 10, 2012 5:15 am
That looks to me like Panasonic's Standard "too much green", not too much yellow. (Note that the bare rock(?) without any gravel(?)/wood chips(?) on it on the right is actually more yellow in the RAW pic.) You might try another Film Mode--Natural or Scenery--and/or adjust the Saturation. But note that you can only adjust overall saturation, not just green.
Or just continue to shoot RAW and adjust in post - Mark
PostPosted: Thu May 10, 2012 2:18 pm
That bare patch on the right is some sand that washed out from the bank onto the aged wood chips. It does look slightly more "yellow" in the raw/developed photo.
I edited the post to indicate which is which. (I thought the photo name would show.)
Thanks, Jim
PostPosted: Thu May 10, 2012 2:46 pm
Here are two more photos that I took to explore color matching.
I would appreciate any comments on the colors. (The raw/developed photo more closely matches what I think I saw.)
Thanks, Jim
