It is currently Tue Jun 18, 2013 9:10 pm
PostPosted: Mon Sep 19, 2011 10:38 am
For the last few sessions after powering down and re-starting saved images are not showing on the screen in Playback mode (Which I think I recently switched on). Older images show but new ones pause for a bit and the screen stays black.
Panasonic DMC-TZ7 and Nikon Coolpix 450
PostPosted: Sun Apr 01, 2012 10:31 am
We are having the same problem with our Lumix TZ5 - anyone know what is causing it? It has happened on two different memory cards, but interestingly the images are displayed when the card is inserted into our laptop.
PostPosted: Fri Apr 06, 2012 5:10 pm
Same problem with my FZ28, and on the FZ18 it's become that big that hundreds of pictures simply disappear...
Heard this many times more, it's really a big problem for Panasonic cameras. Why? I dont know.
PostPosted: Fri Apr 06, 2012 5:31 pm
I did find an answer for this, it certainly has worked for my camera.
If you put your memory card into a laptop or card reader and edit it in anyway ie change the rotation of the image and your reader saves this new image, it wont display on your camera. I did a test on this theory and it worked, so hope that might solve the problem for anyone else.
