It is currently Thu Jan 19, 2017 9:12 am
 Post subject: Lumix FZ35 Software Help
PostPosted: Sat Feb 27, 2010 3:10 pm
I'm running Ubuntu, and was wandering if I can safely connect my data cable? The PhotofunStudio software does not say Linux compatable.
Regards
Marty
 Post subject: Linux
PostPosted: Sat Feb 27, 2010 6:12 pm
I have no idea if your version of Linux will see the "device", but I do know
that PhotoFunStudio is released for "Windows Only" on my CD.
Basically I don't use the supplied software, and prefer to use the SD card
directly into my notebook SD slot!
 Post subject: Re: Linux
PostPosted: Sat Feb 27, 2010 6:35 pm
That is what I had always done, just plug the card into my card reader under windows. I did find that the PhotofunStudio, was slow to load when I was useing windows xp media center.
I switched to ubuntu because it has a lot of free open source stuff. And Kdenlive is better than windows movie maker.
PostPosted: Sun Feb 28, 2010 6:56 am
Hi,
I haven't used Ubuntu, but I have used PCLinuxOS GNOME, which should be pretty much similar. There is a program in Linux called WINE, which can run Windows programs on Linux. You can get is from the software support in Ubuntu. However, different applications have different compatibilities with WINE, so no guarantee that if will work.
Hope this helps,
Jinay.
