It is currently Thu Jan 19, 2017 7:47 pm
PostPosted: Mon Mar 17, 2008 6:00 pm
I'm attempting to DIY 2 narrow table top 55 Watt 3500K Flourescent Lights (F55W2D) that are actually dimmable for table top use with a tent.
These lamps are only 8" x 8" as I'm doing only Macro and small items and should provide even lighting plus they will be dimmable.
My only concern is that they are 3500K and presently no one manufacturers a 5700K equivilant.
Question: My Olympus 510 has many equivilant settings for these applications, but will setting the white balance to either 4000 / 4500 / 6600K / or Custom equal that of a true 5700K specific designed Lamp? Will it result in off color?
The other reason for this DIY is that I have very little area to set this up and these lamps will only have a total depth of 3 1/2" and will allow me to place these quite close to the tent, getting these lamps gratis is another incentive!
PostPosted: Mon Mar 17, 2008 7:24 pm
Not sure about the settings, but you can (and should) shoot RAW. Then there is no loss of IQ when correcting the wb afterwards...
D810+assorted lenses
PostPosted: Tue Mar 18, 2008 9:36 pm
you can also set the [Fn] button for the ONE TOUCH WB setting. And Manually set the WB by shooting a white pice of paper under the lighting conditions then your camera should be set for that WB
In the end, Shoot RAW.
Leo
3) Canon 7D [EF-S 15-85 & 70-200mm f/4 IS & 50mm f1.4]
4) Leica M [50mm Summicron Pre-aspherical - Silver]
http://www.poetproductions.net
