It is currently Thu Jun 20, 2013 7:23 am
 Post subject: Need help with SP-570UZ?
PostPosted: Sun Jul 11, 2010 5:38 pm
Sorry if this is a wrong place to post this
So my camera, Olympus SP-570UZ (a superzoom camera) has a little problem. When I operate in manual or shutter priority mode, I cant raise my resolution over 3MP? I tried slowing and speeding the shutter but it seems that I cant raise the resolution. If I change to any other mode I can use higher resolutions.
EDIT: Fixed it, I had a thing called Fine Zoom on.
PostPosted: Sun Jul 11, 2010 7:23 pm
Did you check- that you're NOT shooting High Speed Continuous..?
Canon 5D2, 7D, 50D & Canon s95 | Canon Lenses: 28-135mm, 17-55mm, 10-22mm, 15-85mm, 100mm 2.8 USM Macro and the 50mm 1.4 | Speedlite 580EX II and 430EX II |
PostPosted: Sun Jul 11, 2010 10:39 pm
Maybe the camera is trying to use a really high ISO in those modes? Many cameras have reduced resolution when the ISO gets to a certain level. So, try and lower the ISO and see if that solves the problem.
