It is currently Sat May 25, 2013 3:13 am
PostPosted: Mon Feb 15, 2010 1:53 am
If so, what adapter is needed? the MMF-1?
Focusing?
Light Metering?
PostPosted: Mon Feb 15, 2010 8:50 am
What's an original Pen-FT lens?
If you mean the Zuiko lenses for the 4/3 system like the 50mm macro then yes, they will work with an adapter.
Olympus E-30, ZD 9-18mm 4.0-5.6, ZD 50mm Makro 2.0, ZD 14-54mm 2.8-3.5, ZD 70-300 4.0-5.6
Light travel equipment:
Olympus EP-2, µZD 14-42mm , Panasonic 20mm 1.7 pancake.
Cullmann Trento IT Daypack
PostPosted: Mon Feb 15, 2010 8:18 pm
I believe Pen FT was one of the older film Pen standards in the mid-Sixties, which used half of the traditional 35mm frame - so the frame size was 24x18mm. This is still bigger than the (Micro) Four Thirds sensor, so in theory they're optically corrected for the frame size.
http://www.cjo.info/personal/html/ccc/olympuspenft.html
The following company offers a variety of adapters for Micro Four Thirds, so they're probably your best bet:
http://www.cameraquest.com/adp_micro_43.htm
