It is currently Wed May 22, 2013 10:34 pm
PostPosted: Thu Feb 04, 2010 1:22 pm
Hi,
Looks like a fantastic deal to me. However, are micro four thirds lenses more expensive than the usual ones? (conventional DSLRs)
Also, what is the competition for this camera? I am waiting for it to be compared to its class in photo quality and price. Any ideas?
Thanks,
Jinay.
 Post subject: competition
PostPosted: Thu Feb 04, 2010 3:02 pm
Lense prices for micro-4/3 are higher than low-end SLR lens offerings, but lower than the next higher grade (low-end lenses are usually $300-$500 and the next step up hover around $800-$1000). Olympus Zuikos are considered to be some of the best optics out there, second only to Leica. Obviously that varies lens to lens for any given manufacturer and price/quality segment, but typically for the cost you get better sharpness across the lens with very low dispersion and distortion.
The competition in this market is the other PEN Olympus bodies, the Panasonic DMC G* series cameras (also micro-4/3), the Ricoh GXR, the Samsung NX-10 and the Leica rangefinders. Did I miss any? Actually, I would add the Canon G11, though it's not an interchangeable lens system because I think it's trying to entice the same market.
The Panasonic, Canon and Leicas are the only systems I've seen images for. The Canon is good but not SLR quality like the micro-4/3 (IMO). The Leicas are very good and extremely expensive and thus aren't really in the same market segment. The Panasonics have comparable quality. Olympus Lenses are usually considered a bit better quality, but they can be used on the Panasonic bodies anyway and vice versa. The Panasonic GF-1 is pretty compelling too.
PostPosted: Thu Feb 04, 2010 3:05 pm
Gerald W wrote:
The idea of the EPL-1 with a travel lens is exciting to me; but it brings another thought. Why not a fixed zoom as I described above.
Oly has "superzooms" like this, though I don't think they use the 4/3 system for the sensor and other bits. It probably is an obvious next step to push the system cost down and be a really compelling consumer offering. It depends a bit on how that superzoom lens can telescope, I would think.
 Post subject: Not superzooms
PostPosted: Thu Feb 04, 2010 5:14 pm
The very long focal length lenses really require a small sensor to keep the lens size down. I'd be happy with a much more restricted focal length range for a fixed lens travel camera in exchange for the larger sensor. Perhaps the 28-200 mm equivalent of the old Canon Pro 1 fitted in a body similar to the Panasonic FZ30 or 50. I don't think of 28-200 as a superzoom, it's "only" 7.14x! :roll:
Jerry
PostPosted: Fri Feb 05, 2010 1:24 pm
Gerald,
I am no expert, but I will try to answer from what I know:
1. DSLR lens 'superzooms' are usually lower than Superzooms.
2. The FZ50 may have a 12x zoom, but if its wide angle is 35mm (suppose so, I am not sure!) than it means the lens is a 35-420mm lens. Now, if you have a 200mm DSLR lens, Canon will multiply its focal length by 1.6, Nikon by 1.5, and Milonta by 2. So, your lens will be equivalent to a 320mm lens for Canon, 300mm lens for Nikon and a 400mm lens for Milonta! (that one's pretty close!)
3. Don't confuse the mm and X. X is the ratio of the Telephoto to the Wide angle. So, if you have a 50-100mm lens, it is 2X, and if you have a 100-200mm lens, it is still 2X, but it will take you twice as close! So, if you have a camera with a 25mm wide angle with 10X zoom and a 35mm wide angle with a 10X zoom, the Xes may be same, but the 35mm one will take you 1.4 times closer at max telephoto!
Hope this helps,
Jinay.
Quote:
Quote:
PostPosted: Fri Feb 05, 2010 4:39 pm
My "only" 7.14x was meant to be a facetious remark. For a high quality lens, that's a wide range.
I'm also well aware of the mechanics of focal lengths and sensor sizes.
What I was trying to get to was that the physical size requirements of a relatively fast lens matched to a larger sensor restricts focal length range for a camera that's portable and practical. I felt that a faster 28-200 mm equivalent lens for a 4/3 sensor could probably be packaged into a body about the size and weight of the FZ50. The FZ50 has an equivalent focal length of 35-420 and is f/2.8-3.7 with a 1/1.8" sensor, which has a 14 mm diagonal measurement. A lens of similar physical size should allow a 210 mm equvalent lens at f/3.7 to cover the diagonal of a 4/3 sensor. Thus, it seems possible to design a fixed lens micro 4/3 camera with a 28-210 equivalent zoom in a body about the size of the FZ50. Which I think is reasonable.
Jerry
PostPosted: Mon May 03, 2010 9:24 am
I bought one of these as a take everywhere camera. I bought the kit but am on the hunt for a faster all purpose lens. I am impressed with the picture quality and the size with the kit 14-42 lens is perfect. The lens is quite slow hence I am looking for something faster, especially as I bought this to use mostly at night/in restaurants. 10-25 f2.8 would be great (or something like that so I get ~20-50 in 35mm format).
http://www.parismetrotrash.com
PostPosted: Mon May 03, 2010 9:35 am
Alas they haven't done a f/2.8 zoom for it yet, and I'd have to guess if they did it wouldn't be very compact. I love the Panasonic 20mm f/1.7, but obviously you wont get much zoom with that...
PostPosted: Mon May 03, 2010 10:25 am
Still, nice and bright and definitely a walkaround focal length. It might just be the right solution, that or the 2.8 17mm olympus pancake, though considerably slower than the 20mm for sure.
1.7 would be nice....plus it is not expensive.
PostPosted: Mon May 03, 2010 10:32 am
Since getting the 20mm f/1.7, I never used the 14-42 on walkabout again. Personally, I'm not sure I could live with the relatively small aperture of the Oly 17mm, unless you do need something that bit wider.
PostPosted: Mon May 03, 2010 10:38 am
Sold:) I just ordered from Amazon France for delivery tonight (through camlabs links).
I think it will be perfect for my needs.
Providing my new address does not screw up the order, I will get to play in low light tonight....
Thanks!
PostPosted: Mon May 03, 2010 10:03 pm
Thanks for your support!
PostPosted: Tue May 04, 2010 2:33 am
I got the E-PL1 a couple of weekends ago. Was looking for a camera and I was up in the are between a DSLR and a superzoom. Went to the camera shop and the guy suggested looking at this.
So after some research I decided on the E-PL1. So far haven't been disappointed.
Olympus E-PL1
M.Zuiko 14-42mm
PostPosted: Tue May 04, 2010 8:13 am
The 20mm did not arrive last night. I think that is the last time I use the same day delivery from Amazon.fr
Fingers crossed I will receive it tonight... we will see... I hate waiting for new gadgets to arrive:)
PostPosted: Tue May 04, 2010 6:48 pm
It has arrived. Not a bad little lens.
