It is currently Sat May 25, 2013 10:44 pm
PostPosted: Tue Jun 16, 2009 9:11 am
Couldnt find much info on this but I did one reviewer who took IR landscape pics with the e-620 (its further down on this page):
http://www.ppmag.com/web-exclusives/200 ... e-620.html
Note: the exposure times were long (3.2 sec at iso 3200!) but he did use f/16 (I'll be using f/8 at most) and he was using a stronger IR filter than the one I have (which is the Hoya R72). I wonder what the equivalent exposure would be with the R72 at f/8 and iso 1600?
https://www.photoshop.com/user/alex_the_great
PostPosted: Tue Jun 16, 2009 11:27 am
There doesn't seem to be much info on the I-ray characteristics vs R72, other than it claims to pass 700-1100nm compared to the nominal 720+ of the R72. So in that respect I'd suspect they're going to be very similar.
Also, just for info, I have recently bought two unbranded R72 equivalent filters from ebay, at under 1/3 the cost of the Hoya original. Side by side, I can't see any significant difference in the camera IR output between them so far. One of them does appear a little brighter by eye. So if people want to get in on the cheap, the unbranded ebay ones seem just fine. I'll write more on this later...
PostPosted: Tue Jun 16, 2009 9:42 pm
Thanks I got my Hoya R72 on the cheap too... from 2filter.com, it was around $32... I use it with my Oly e520 and the typical exposures I get are something like f/5.6 and 1/3 sec exposure at iso 1600 and it does autofocus fine, I compose using the LCD and live view and I can hand hold the shots at iso 800 and 1600 because of the IS. Do you think, based on those numbers, the E520 is more IR sensitive than the e-30 or e-620?
PostPosted: Wed Jun 17, 2009 7:32 am
Do you think this is a low level of noise for an e-520 at iso 1600? The rest of the particulars are f/5.6 and 1/3 sec shutter speed handheld with IS. I did a channel swap and autolevels:
http://gi73.photobucket.com/groups/i206 ... 0878ir.jpg
I find that if you keep saturation and sharpening to default values you dont see as much noise.
PostPosted: Wed Jun 17, 2009 11:48 am
In general, I find IR to be quite noisy especially if you work in false colour as the green/blue channels tend to be very low to start with. So combined with ISO1600 I think that is within general expectations.
