It is currently Fri May 24, 2013 1:31 am
PostPosted: Wed May 27, 2009 1:42 am
:( I tried My camera is Olympus E-520 connect olympus master #2 but it unable to detect Olympus Master with firmware update for 70-300mm lens.
Call olympus service center or help me how to use right.
I took screenshot of this firmware update.
PostPosted: Wed May 27, 2009 6:13 am
make sure to install all the drivers windows installs when you connect the camera.
This worked for me:
When you connect the camera to the computer, on the camera you can select various options such as "storage" and others, connect the camera to the computer once under EACH of those selections [so you will have to do it 3-4 times] and install whatever drivers windows tells you to install. Should install automatically, just click continue and stuff.
E-3!
12-60 2.8-4.0
12-60 2.8-40 [Also going]
40-150 3.5-4.5
70-300 4.0-5.6
Fl-48
PostPosted: Wed May 27, 2009 5:01 pm
Thank you for your reply.
The drivers windows did not install during I connect the camera.
I need drivers windows download.
PostPosted: Wed May 27, 2009 5:36 pm
I've seen that message before. I just kept trying and trying and trying, and then it worked.
Sony NEX-3 | 16/2.8| 18-55
My FlickR!
