It is currently Sat Jan 21, 2017 2:28 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu May 07, 2009 8:41 pm
Just for fun: this is a 100% crop of the same test photo (iso 200) of the following camera's: E3. E30, 50D and D90. So my question to you is obviously which one is which. Please don't look at the site where I took the photo's. :)
Olympus E-M5, 9-18, 12-50, 25 f1.8, 45 f1.8, 12-60, 40-150, 70-300
PostPosted: Thu May 07, 2009 11:00 pm
I'll bite: Top L to R: D90 & E30
Btm. L to R: 50D & E3
When will you let us know ?
PostPosted: Thu May 07, 2009 11:13 pm
Top Left: E3
Top Right: E30
Bottom Left: 50D
Bottom Right: D90
The top left crop is bigger, so I had thought that it might be the 50D then. But the color and noise just didn't quite jive w/ 50D.
PostPosted: Fri May 08, 2009 4:38 pm
It depends, I want some more reactions first, but probably on monday.
Btw, today I tried the E3, E30 and the E620. I tried the E620 with 12-60. It's possible and it will make good photo's, but it's a little out of balance and not easy to hold in 1 hand. The E30 felt much better.
Hans
PostPosted: Sun May 10, 2009 4:54 pm
my guess: top left: 50d right: e-30
bottom left: e-3, right: d90
PostPosted: Sun May 10, 2009 9:41 pm
[quote="Hans"]
Hi Hans:
I really like the button layout of the E30, but it was the larger viewfinder that really sold me on E30....can easily use manual focus and see my settings for the first time....not quite the E3 viewfinder, but still excellant & worth the size & price IMHO.
Regards
PostPosted: Mon May 11, 2009 5:43 pm
Yes, so far I like the E30, so I think I will buy that one.
PostPosted: Mon May 11, 2009 6:20 pm
Hello, E-620 beats E-30
Olympus E-620 is Best Digital SRL Entry Level. It was worth.
http://www.tipa.com/english/award-detai ... ntry+Level
Nikon D90 is Best Digital SLR Advanced.
I found other website copied cameralabs after I search olympus E 620 vs E-30 in Google.com
ISO Wars: D90 vs E620 vs XSi/450D at Camera Labs
http://www.1001noisycameras.com/2009/05 ... -labs.html
I check 1001noisycameras.com has private information. Who owns it?
http://whois.domaintools.com/1001noisycameras.com
PostPosted: Mon May 11, 2009 6:33 pm
I don't really consider the E620 completely entry level.
It has a lot of possibilities and it's above entry level. Entry level are: D60, 1000D, E450, K200, A200.
That the E620 wins one category does not mean that it is better then the E30. It just means that they consider the D90 better then the E30 and I can understand that, although both of them have their advantages.
PostPosted: Mon May 11, 2009 8:40 pm
So who was right? It's actually not that difficult. idavis was right.
Left top is the pic with the largest magnification and there is just a little more detail, so that must be the highest resolution as you can expect from a 15 MP camera.
Bottom left has the smallest magnification and the detail seems just a little less then the others, so it must be the E3 (10 MP).
You may expect the color of both Olympus camera's to be similar, so top right should be the E30.
Finally the the remaining one should be the D90.
The conclusion can be that a 15 MP sensor will make some difference, but it's just small and even the 10 MP sensor will almost give the same result as the 12 MP sensors.
PostPosted: Mon May 11, 2009 8:52 pm
I almost got it right ... but I went against my instinct that the top left crop was larger b/c of the larger 50D sensor and instead relied on my supposition that the E3 image would be sharper than any of the others.
PostPosted: Mon May 11, 2009 8:58 pm
Yes, you mentioned that, but the difference between 10 and 15 MP is simply to big even though most of Canon's lenses cannot match the sensor.
PostPosted: Mon May 11, 2009 10:57 pm
yep, that's pretty much how i made my guesses: size, color, noise.
PostPosted: Tue May 12, 2009 6:58 am
You people should not forget that photography is not about pixel peeping. Noise won't be seen on anything smaller than a poster print and then only if you stand about one inch in front of it. Any of the modern cameras can make pictures that look fine when printed.
There are more important aspects than noise and you always should consider the lenses to go with the body. The best sensor won't help you much if you use a superzoom lens. That's the good thing about Olympus. Every lens (except that old 17.5-45mm kit lens) delivers awesome performance for it's price. Check Gordon's 7-14mm review, or check DPReviews reviews on the 14-42, the 50mm, the 9-18mm and the 12-60mm.
PostPosted: Tue May 12, 2009 7:10 am
PrinzMegahertz FTW!
