It is currently Wed May 22, 2013 7:48 pm
 Post subject: viewfider eyepiece cap
PostPosted: Fri Jun 15, 2007 7:15 pm
Could someone please tell me when and why you would use this?
Nikon D80, 18 /200mm VR lens, B+W filters (UV & cir pol), Manfrotto 055proB/322RC2
 Post subject: Good Question!
PostPosted: Fri Jun 15, 2007 8:26 pm
Read the manual.
Like I did.
And still not understand.
Like I did.
:wink: :lol:
PostPosted: Fri Jun 15, 2007 8:37 pm
yep!
PostPosted: Fri Jun 15, 2007 9:07 pm
Basicly light can get in the viewfinder in long exposers in some case and screw things up.
Don't live me credit for this copied it of some other forums :P
The problem is the exposure meter. The sensors for the meter are located in the prism area, and of course they measure whatever light hits them. They cannot distinguish between light arriving from below (ie through the lens) and light arriving from above (ie through the viewfinder).
This can be quite significant in some cases. If you're shooting with the sun at your back, you could pretty much have the sun shining directly on the meter, causing the picture to be drastically underexposed. Of course, if you are looking through the finder when the reading is taken, you're blocking most of that, so it's normally no big deal. But if you're using the self timer, a cable release or a remote trigger, you aren't there to block that light.
Using the eyecap is not necessary - anything that blocks the light is sufficient. Your hand, a dark t-shirt, etc all work.
PostPosted: Fri Jun 15, 2007 10:24 pm
Antony's right - the eyecap is used to stop stray light entering the viewfinder when you don't have your eye up against it. Tripod users beware!
To be honest though, I've never experienced it as an issue.
PostPosted: Sat Jun 16, 2007 9:27 am
Antman, Gordon
I thank you.
Tony
Users browsing this forum: oldCarlos and 2 guests
