It is currently Fri Jan 20, 2017 2:20 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jun 10, 2007 12:58 am
Gordon Laing wrote:
You're right Darrin, the old rule was 1 / (effective) focal length to avoid camera shake, so technically speaking, yes, it should be around 1/300! But since this problem was visible at 1/250, I don't think it would go away at 1/300!
True!
The grip technique can make or break this rule...
Darrin
PostPosted: Sun Jun 10, 2007 9:28 am
Looking again at the photo I find it hard to believe that this is the result of "normal" camera shake! there are clearly to pictures overlaid in one: look at the wheel! There must have been a exposure in one place, then a very fast displacement to the next position and an exposure in the new position. That looks more like a knock at the cam or it may be some prismatic effect in the lens. In the letter case, the lens is clearly misadjusted and should never produce clear photos.
That could be easily found out with more pics!
D810+assorted lenses
