It is currently Sun Jan 22, 2017 12:24 pm
PostPosted: Fri Aug 16, 2013 3:28 am
I am using a Nikon D800 with I meike battery grip
Have some doubts in the mind from the day 1 i own the battery grip!
Which battery option is better in this combo, using the EN -EL 15( original) inside the camera and adding 8- AA batteries inside the grip
or adding an extra EN-EL15 on the grip.
Meike provided two adapters, 1 for holding the original battery and other one for holding 8 AA batteries
Which 1 is the better option
Second doubt is
original battery is rating 7 Volts 1900mAh
But a single AA( eneloop in my case) is 1.2 V and 1900mAh
thats means there will be the power difference in the two setups!
Will that voltage difference cause damage to my gears??
Bit confused
Can someone give some light regarding my quarries
Hope I managed to convey the doubts that i am having in my mind and this is the right section to ask my question ?
CAMERAS:- Nikon D800 & Sony H50
LENSES:- Nikon AFS 50mm F1.8 G, Nikon AFS 24-70 F2.8 G, Sigma APO 70-200 F2.8 EX DG OS HSM
Wish list:- Nikon SB 700, Elinchrom FX 400
