It is currently Sat May 25, 2013 6:20 am
Post new topic Reply to topic  [ 59 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Wed Apr 27, 2011 7:50 am
After some leaks on the web last week, the new 50mm standard-lens from Nikon is now reality with Amazon.com offering preorders for 218 USD. Nikonrumors is quoting an expected delivery date of June 16th, the German Nikon site says "beginning June" at 229 EUR (that would be incl. 18% VAT).
The lens looks like a larger copy of the 35/1.8G with added distance-window and one aspherical element. MTF-curve looks good, better than the AF-S 50/1.4G, but that was (almost) to be expected, as both lenses are measured wide open.
See more details of this lens over at Nikon-central.
If the optical construction and the price is anything to go by, I'd expect performance similar to the DX 35/1.8. And should I get my hands on a copy I'd certainly be testing for transmission too.
PostPosted: Wed Apr 27, 2011 7:59 am
Now, let's have some side-by-side comparison of the new AF-S 50/1.8G, the DX AF-S 35/1.8G and the AF-S 50/1.4G
Image Image Image
See the respective MTF-charts side-by-side:
Image Image Image
...and remember that the DX-lens (middle) only covers a 14mm image circle, so for an apples-to-apples comparison you have to take the left half of the 50mm MTF-chart (up to 14mm)
Now for the respective cross-sections:
Image Image Image
Pretty similar at the back-end, but the 50/1.8G has one less lens-element in the front-end.
An interesting tidbit from the technical data is the MFD (minimum focus distance) of 45cm and a max magnification of 1:6.7. This is not bad for a 50mm standard lens (actually the same as with the AF-S 50/1.4G)
PostPosted: Wed Apr 27, 2011 8:12 am
And before there's more information about this new lens you might want to refresh your memories of my reviews of the AF-S 50/1.4G and the DX AF-S 35/1.8G.
PostPosted: Wed Apr 27, 2011 8:21 am
Well,Canon officially lost all advantages of their systems for begineers,now that the AF-S 50 F/1.8 is out.(or soon will be) The Canon "Kinder Surprise" 50mm F/1.8 will atract less & less people,compared to these 2 sharper & better built lenses.
Visit my work here
PostPosted: Thu Apr 28, 2011 4:42 am
Can't wait for this lens. I believe I read it'll be roughly $200 MSRP. Can't beat that. Thanks Thomas.
Jason
Just a new guy learning his way
Film: Olympus XA2
Digital: Nikon D3100 w/SB-600: , Nikkor 35mm f/1.8G, Tokina 12-24MM F4 Pro II
My Flickr: http://www.flickr.com/photos/jkmcdonald/
My Blog: http://jmcdonaldphotography.tumblr.com/
PostPosted: Thu Apr 28, 2011 7:15 am
Looks like a neat new lens, I can't wait to see how this compares with the 50mm f/1.4.
-Evan
- Ansel Adams
PostPosted: Thu Apr 28, 2011 7:38 am
my prediction, performs better wide open, but no difference at around f/3.5 and higher. The only thing that might even be better is the AF-speed that will probably make the lens less accurate but people wanted a faster focussing 50mm
- Wout -
PostPosted: Thu Apr 28, 2011 10:52 am
I agree with Wout. My 50 1.4 is very soft wide open. Not an issue, and quite nice for portraits, but more sharpness would be nice in some situations.
PostPosted: Thu Apr 28, 2011 3:29 pm
Nice to see a focussing window.
+1 on the predictions. Sharper and faster focussing.
PostPosted: Thu Apr 28, 2011 7:23 pm
Nice update from Nikon & hopefully faster & quieter than its predecessor
Soon.....Image
PostPosted: Fri Jun 10, 2011 3:14 pm
Today a copy of this lens arrived at my doorsteps so the next two weeks will be a frenzy of testing.
Stay tuned for the final verdict...
PostPosted: Fri Jun 10, 2011 8:53 pm
Some test-shot at about 85 cm distance. Shows sharpness and bokeh.
Poppies @ f/1.8 (left, 1st) and f/4.0 (right, 2nd):
Click through the image to access the large originals.
PostPosted: Sat Jun 11, 2011 4:04 pm
Poppies are such wonderful subjects for test-shots: Their stems have very fine hair!
Here are some first observations from comparisons side-by-side on a D300 DX body with the Nikon 50/1.4G seem under controlled conditions.
They seem to confirm what the MTF-Charts indicate: the new 1.8G lens is a little sharper/contrasty wide open than the 1.4G lens. At f/2.0 the differences are almost gone, that is you need some serious pixel-peeping to find any.
There might be a little bit more field curvature on the 1.8G but that can only be tested on flat targets.
Bokeh seems comparable between both lenses with the 1.4G perhaps a little more nervous in front of the focal plane. But again that is something that I'll have to specifically test for.
Transmission didn't show any obvious differences, but there is a real 2/3 stop advantage of the 1.4G and also the oof-blur is clearly stronger at f/1.4 than at f/1.8.
Here are both lenses wide open (f/1.8G 1st, f/1.4G 2nd), focus is on the center. Click through to large originals:
Nikon AF-S 50mm f/1.8G at f/1.8, 1/500, ISO 200
Nikon AF-S 50mm f/1.4G at f/1.4, 1/1000, ISO 200
So that's it for today. Please understand that these are preliminary findings from just one series of shots. I'll be off for Whitsun but will be reporting back as soon as I have more results.
See ya!
PostPosted: Sat Jun 11, 2011 7:46 pm
The 50mm 1.8 does definitively seem to be sharper, but that's to be expected. The local camera shops are finally getting them in stock, I think that I'll be down there today testing out the two lenses.
-Evan
- Ansel Adams
PostPosted: Sat Jun 11, 2011 7:51 pm
Btw...
35mm/1.8G: Size 70x53mm, weight 210g, filter-thread 52mm, street-price* 180EUR (DX-only!)
50mm/1.8D: Size 63x39mm, weight 155g, filter-thread 52mm, street-price* 130EUR
50mm/1.8G: Size 72x53mm, weight 185g, filter-thread 58mm, street-price* 190EUR
50mm/1.4G: Size 74x54mm, weight 280g, filter-thread 58mm, street-price* 330EUR
So the new 50mm/1.8G lens is much larger in size than the old Nikon AF 50/1.8D and very close to the 50mm/1.4G.
But it is almost 100g lighter and 140EUR cheaper than the 1.4G.
Maximum magnification with all three 50mm is equal: 1:6.6.
All f/1.8 lenses have 7 diaphragm blades, the 1.4G has 9 blades.
All "G"-type lenses have rounded blades.
All prices incl. 19% VAT
