It is currently Sun May 19, 2013 8:59 pm
 Post subject: Nikon battery issue
PostPosted: Thu Apr 26, 2012 10:35 am
Just seen this on another forum, thought it would be of interest to Nikon owners here and relates to the following:
Quote:
This is an important announcement regarding the EN-EL15 battery which is used in the Nikon D7000, D800, D800E and Nikon 1 V1 cameras.
https://nikoneurope-en.custhelp.com/app ... a_id/52326
Speedlight SB-700
http://keystrokesukimages.com
 Post subject: Re: Nikon battery issue
PostPosted: Thu Apr 26, 2012 5:31 pm
Mine will be exchanged soon.
PostPosted: Fri Apr 27, 2012 4:15 am
Thanks for the info, both my batteries are ok.
PostPosted: Fri Apr 27, 2012 10:12 pm
My D7000, purchased late 2010, is fine. It's marked with a "B", so I'm assuming that most 2010 and early to mid 2011 models are fine.
-Evan
- Ansel Adams
PostPosted: Sat Apr 28, 2012 7:28 am
To identify the faulty batteries: "If the 9th digit of the EN-EL15 battery lot number is E or F then the battery needs to be replaced as it may be affected by this issue."
PostPosted: Sat Apr 28, 2012 10:02 am
Thanks for the heads up, checked mine A 8)
