It is currently Wed Jan 18, 2017 4:40 am
PostPosted: Fri Nov 11, 2011 9:22 pm
I could use your advice. I am using an SB-600 flash with my D5100 and getting relatively good results by bouncing my flash off a ceiling or wall. I question whether my results would be even better if I used a diffuser in addition to my bounce. My concern is whether using both bounce and a diffuser would result in too little light coming from my flash. I have read about the advantages of using a diffuser to get a softer light (much the same advantages as bouncing the flash off a ceiling or wall). Do any of you have experience in successfully using a diffuser with your SB-600 (or similar) flash and using bounce at the same time? Thanks.
PostPosted: Sat Nov 12, 2011 12:14 am
Welcome to the forums mate!
Have a read here about flash diffusers: http://www.cameralabs.com/forum/viewtopic.php?t=19906
 Post subject: flash diffuser advice
PostPosted: Sat Nov 12, 2011 12:33 am
Thanks for the link to the article on flash diffusers. Very informative.
