It is currently Fri May 24, 2013 5:48 pm
PostPosted: Mon Sep 05, 2011 5:14 pm
I was flicking through the photos of my trip to PEI and came across a couple disappointments. I was taking HDR's of some windmills. In doing so I wanted some with a long exposure to get some motion blur so I used an ND8 filter. I took the shots in aperture priority mode from -2ev to +2ev in 1ev intervals. I've done this type of shot before with the exact same gear and filter and didn't have a problem.
I didn't bother to check the images so I just packed up the tripod. Anyway, the photos came out really super dark. I'm not sure what happened. Below is a photo of the +2 ev bracket. The meta data for this shot is:
I know it's a lost cause a this point, but I really would like to know what might have happened to prevent it in the future.
EV bias, +2
f/22
ss 0.8s
program: aperture priority
Metering mode: pattern
Camera:
Nikon D200
Lens:
Tamron 17-50mm, f/2.8
Trevor Harris
Nikon D200
SB-600
YN-560 II
YN RF 603 x 4
Tamron 17-50mm f/2.8
Nikon 50mm f/1.8
PostPosted: Mon Sep 05, 2011 5:29 pm
That is weird. Tbh though I havent used the D200 enough to know how its meter reacts in different conditions.
But if you're saying youve taken similar shots before and were fine, I guess it is just a freak thing.
PostPosted: Mon Sep 05, 2011 7:40 pm
There could be numerous reasons for the meter to react like that. The question is whether the camera is to blame. What I like is that you did not chimp through the images you took. That's how a true hearted photographer works.
What could have gone wrong?
Lens not perfectly mounted
Minimum shutter speed set in camera
The meter's limit is around 16 EV if I remember correctly. Maybe the ND8 had its effects?
Or is the meter defect?
Personally I use ND filters quite intensively and prefer manual mode along with spot metering (exposed for the whites). It is quite difficult for us to tell what went wrong. Maybe you could give us a link to the full EXIF data?
PostPosted: Mon Sep 05, 2011 8:05 pm
I would guess it's most likely the filter messing with the metering system. You're probably better off taking a test shot without the filter to get a correct exposure. Then add the filter, go into manual mode, and do the calculations needed for the appropriate exposure.
PostPosted: Mon Sep 05, 2011 8:08 pm
I appreciate the compliment, I think, but I don't understand it. What does "chip through" mean?
I stopped by the side of the road to take this shot and a few others. So the camera was off, then on to take these (underexposed). Switched it off, and then an hour or so later back on again and those were fine. Since then I've taken hundreds of photos and they're all ok.
For your what could have gone wrong list:
1) Possibly, but not likely. It was thrown in the car before and after this so I guess it is possible that it knocked off and then knocked on again. I didn't switch lenses at all during this day, however.
3) When using flash, it's set to 1/60. But without flash there isn't any. All photos in the full 5 brackets are underexposed. This happened for the 4 HDR's I took during this period totalling in 20 consistently underexposed photos.
4) Never heard of this "meter limit". Could you explain? The aperture is open to 2.8 during the meter process isn't it?
5) Doubtful since hundreds of photos taken after this came out fine.
Trevor Harris
Nikon D200
SB-600
YN-560 II
YN RF 603 x 4
Nikon 50mm f/1.8
PostPosted: Mon Sep 05, 2011 8:45 pm
Trevor Harris wrote:
What does "chimp through" mean?
Chimping explained: http://en.wikipedia.org/wiki/Chimping
Could you explain "meter limit"?
I should have been more precise. Every meter has a measuring range. Which basically means it requires a certain amount of light for it to work. On the other hand, in your case it must have received too much light, since it underexposed.
Are you sure you had the camera set to aperture priority or did not accidentally hit the AE-Lock button? The Exposure compensation was set to +2 EV?
PostPosted: Mon Sep 05, 2011 9:36 pm
Is it posible that the camera had been set to -EV for a previous shot & not re-set?
(Thus meaning all the BKT'ed shots for the pic, were all under what you were expecting)
PostPosted: Mon Sep 05, 2011 9:53 pm
@theorigamist: I'm not sure that the filter is messing with the metering system since I've used it before in a similar situation and it worked fine then. However, what you suggest would definitely work.
@Bernie: My exif data says it was indeed in aperture priority. Not sure about hitting the AE-Lock button, but on my D200 the AE-Lock button only holds the exposure as you press it and then recalculates as you release. I had the HDR's set up on a timer as to avoid camera shake so I definitely wasn't holding the button during the shots. The Exposure compensation was set to +2 EV for this shot, is that what your asking? Or are you asking something slimier to oldCarlos in that the compensation was dialled in on top of the bracketing. so if I was at -3 (for example) before the bracketing then the shots would have been -5, -4, -3, -2, -1.
@oldCarlos: See previous note.
Trevor Harris
Nikon D200
SB-600
YN-560 II
YN RF 603 x 4
Nikon 50mm f/1.8
