It is currently Fri May 24, 2013 4:06 pm
 Post subject: New D7000 Problems?
PostPosted: Thu Apr 28, 2011 10:57 pm
Hi Guys
As per the title I have bought a new D7000 today and have taken what I thought was one of my best pics ever. When I looked at it on my computer there is a wave like in the shape of a semi circle through it. :? What caused this does anyone know?
Taken with a 18-200mm Nikon VR lens. ISO 100, F8 at 206secs. I also used a Hoya ND400 to give me the longer shudder speed.
Here is a link to Flickr to see it larger.
http://www.flickr.com/photos/pjos111/
Nikon D7000. Nikon AF-S DX 18-200mm f/3.5-5.6 G ED VR II Lens, Nikon 50mm 1.8D, Tamron 10mm-24mm
PostPosted: Fri Apr 29, 2011 2:56 am
Hmmm
What in the sky is reflected in the water more darkly, making me think that it is real (to some extent).
Without seeing image information in detail I can only think that any defect may be limited to "stepping" in the JPEG, but it may only be emphasising what is already there.
The higher the ISO the more likelihood in picking artifacts.
Other than this, I'm stumped. My D7000 has behaved commendably.
HCC
PostPosted: Fri Apr 29, 2011 5:33 pm
I agree, it looks like jpeg color stepping to me too. What quality did you shoot at?
PostPosted: Fri Apr 29, 2011 5:58 pm
I shot this in Jpeg Fine ( large ) What is color stepping? :?
Paul
Just to add. I enabled Long exposure NR reduction.
PostPosted: Sat Apr 30, 2011 10:53 pm
Color stepping occurs because jpeg images use only 8bits (i think, correct me if im wrong) per pixel for tonal value. Meaning you only get 256 different tones for a color. While this is not an issue under most conditions, it starts to show under challenging lighting conditions. Such as very dark scenes. Yours is a very good example.
Try shooting in raw (lossless compressed 14bit) 14bit would translate to 16384 tonal values.
I hope that made sense. And i hope im not wrong :)
PostPosted: Sat Apr 30, 2011 11:04 pm
Close:
8 bits per color channel, 3 channels per image. RAW has more bits, which means more data, and should mean better quality, mostly noticable in color gradients, highlight detail, some shadow detail/SNR, and perhaps some added sharpness due to a better bayer interpolating algorithm. :)
