It is currently Sun May 19, 2013 3:31 pm
 Post subject: SD Card Help?
PostPosted: Sun Apr 03, 2011 9:18 pm
I have just bought a D3100 and it came bundelled with a 4GB Nikon card. I want to upgrade to a better card ASAP. For my LumixTZ10 I needed a Class 6 for the HD Video, do I need to look for a certain class for the Nikon? I am just thinking of burst shooting etc? Can anyone reccomend somthing?
Will post some sample shots soon!
Thanks in advance!! :D
PostPosted: Sun Apr 03, 2011 9:34 pm
I don't think the nikon card is bad, but if you must get a new card, a Sandisk class 4 or class 6 sounds good.
PostPosted: Mon Apr 04, 2011 12:17 am
I've always been under the impression that class 6 cards are the best for dslr's? Or is it class 4 is for dslr's and class 6 is for camcorders? I can never remember.
Jason
Just a new guy learning his way
Film: Olympus XA2
Digital: Nikon D3100 w/SB-600: , Nikkor 35mm f/1.8G, Tokina 12-24MM F4 Pro II
My Flickr: http://www.flickr.com/photos/jkmcdonald/
My Blog: http://jmcdonaldphotography.tumblr.com/
PostPosted: Mon Apr 04, 2011 7:20 am
Class 10 is best, but class 6 is sufficient. It is only a recommendation by Nikon, you are not limited by using only a certain class cards. I would say try out your card to see if it does what you want it to do, not just stare yourself blind at numbers alone. As for Burst shooting, doesnt the D3100 have only a few fps, so there isnt a need for a fast buffer cleaning?
- Wout -
PostPosted: Mon Apr 04, 2011 11:02 am
Well, the class system indicates the absolute minimum sequential writing speed the card has to maintain. So class 4 writes at AT LEAST 4 megabytes/second. Class 6 at least at 6 megabytes/second.
However, I have found that my Sandisk class 4 card writes with about 10-11 megabytes/second. It's a little bit faster than my transcend class 10 card :roll:
PostPosted: Mon Apr 04, 2011 7:43 pm
For my 3100 I use class 4 cards. The only issue I have is when converting from RAW it does seem to take a little long. Could this be fixed by say a class 6 or 10 or would I not notice a big difference? Or, is it my computer itself?
Jason
Film: Olympus XA2
PostPosted: Mon Apr 04, 2011 7:57 pm
RAW conversion on your PC should have nothing to do with the card. You just transfer all the files to your PC, and then edit them.
NEVER edit pictures directly from the card, this means multiple writes to the same area on the card and can severely decrease the life span of the card.
PostPosted: Fri May 27, 2011 5:11 pm
Having two 'noname' Class 6 cards mine (SDHC) are dropping frames. so my advise is to get at least a Class 6 Sandisk card. It'll be worth every penny!
PostPosted: Fri May 27, 2011 6:43 pm
I use the new SanDisk Extreme Pro UHS-1 sdhc card (UHS-1 is faster than class 10) and it is absolutely flawless. If you are looking for a cheaper alternative the Transcend class 10 sdhc cards are very good value for money and I have had no problem with mine.
