It is currently Fri May 24, 2013 3:13 pm
PostPosted: Sat Feb 19, 2011 2:28 pm
Hi,
Which Nikon flash do you recommend for D7000? Thanks! :D
PostPosted: Sat Feb 19, 2011 2:34 pm
SB-600, or if you have the money SB-700. If you dont mind lugging around some extra weight the SB-900, but be aware it will be very top heavy.
- Wout -
PostPosted: Sun Feb 20, 2011 3:39 am
Hi mclovin,
I use SB400 when I can and the SB600 when it's required. I can get 2 SB600 for the price of one SB900 which I would prefer.
The SB400 recycles faster than any of them and is great for daylight photography...fill. I angles only up, but most of the time that's plenty for me.
It really depends on what you want to do with it. I like to lug as little stuff around as I can, so the small form factor of the SB400 is perfect for me. But if you must have more power, larger ones are more suitable.
Good luck with your choice!
Cheers :-)
PostPosted: Mon Feb 21, 2011 2:06 pm
You could choose SB-600 it's a very nice flash, light , fast to recycle.
You can also use several flash with wireless, and work with all of them.
And it's cheap :P
PostPosted: Sun Feb 27, 2011 5:30 am
Depends on your budget, the SB-600 is a very capable flash, however the SB-700 is even better, the SB-700 is also much more expensive. If you can afford it, go for the SB-700 for sure, otherwise the SB-600 is still a great choice.
I personally wouldn't recommend the SB-400, I really think that it's just a slightly improved pop-up flash. For an external flash, the power isn't superb, and it's only real advantage is that you can bounce light. It is portable though.
-Evan
- Ansel Adams
