It is currently Sun Jan 22, 2017 10:43 pm
PostPosted: Fri Jan 21, 2011 5:55 pm
Currently shooting a sequence of loCA comparisons between the 35/1.4G, 50/1.4G and 85/1.4G.
Seems the 85mm is the worst of all three, the 50mm looks like the tamest.
Will do f/1.4...f/5.6 comparison as loCA is still slightly visible even at f/4.0.
Will also test whether loCA removal in CaptureNX2 is successful with these test-shots under any circumstances. But as the some tests already showed, there's not much hope. In real life loCA removal seems to work sometimes though...
D810+assorted lenses
PostPosted: Fri Jan 21, 2011 9:07 pm
Here's the result for the AF-S 85/1.4G showing a crop at below 50%, followed by the AF-S 50/1.4G and lastly the AF-S 35/1.4G:
85mm:Image
50mm:Image
35mm:Image
Clicking through the image gives you access to the 100% crop. Processing was done in CaptureNX2 with standard setting meaning lateral CA removal was ON, longitudinal CA removal=OFF. You can see the greenish (background) and reddish (foreground) hues even at f/5.6.
To me, the 85mm prime seems the worst, followed by the 35/1.4 and the 50/1.4.
Fortunately CaptureNX2 can reduce the coloration quite effectively. For the results have a look at the individual reviews: 85/1.4G, 50/1.4G, 35/1.4G.
PostPosted: Fri Jan 21, 2011 11:13 pm
And what do you know, the lens with the least LoCa's is also the cheapest!
Users browsing this forum: Yahoo [Bot] and 2 guests
