It is currently Fri May 24, 2013 9:12 am
PostPosted: Tue Jan 30, 2007 6:23 pm
Just thought id mention it in case anyone missed it;
for windows users;
http://support.nikontech.com/cgi-bin/ni ... _topview=1
Or you can just log into your support section of your corresponding country and find it there.
My PC: AMD X2 4600, 2gb ram, 8800gtx, Monitor; NEC 20WGX2
Gear: Nikon D80, 18-70mm
80-200mm F2.8
PostPosted: Wed Jan 31, 2007 11:16 am
Thanks for that. I just upgraded my firmware. It was a very straightforward process that took less than 5 minutes.
My photos on SmugMug
PostPosted: Tue Feb 20, 2007 10:00 pm
I will not mess with my D80 before I go to New Zealand. Anything goes wrong, the body goes to the service?!?! No chance!
After I come back from NZ, I'll upgrade...
PostPosted: Fri Mar 02, 2007 11:21 am
Are there any details on what the upgrade does?
[edit] If i had bothered to actually click the link I would've found the answer to that. :)
It's nice to see that Nikon have thought of us Mac users. /sarcasm
Oh well.
PostPosted: Mon Mar 12, 2007 3:19 am
Even after re-reading the instructions from Nikon I can't see how to select firmware A. The only one that can be upgraded is firmware B. Help, please.
Best regards,
Jim
PostPosted: Mon Mar 12, 2007 3:28 am
Never mind. I figured it out after I went up a little higher in the instructions.
I found I needed to copy of part A update data to the card, put it in the camera and run the update. Then delete the part A update file and copy the part B update file and do the same thing again.
Everything's fine.
Best regards,
Jim
