It is currently Sat May 25, 2013 3:07 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Wed Jan 13, 2010 9:25 am
Hello all Nikon forum users. I am starting this thread, because many people maybe have a good use for it.
Comment on this thread here.
So far the cameras that apply to this thread:
    D40(x), D60, D3000, D5000, D3100
I would like to start off with the Nikon lenses that will autofocus on these bodies:
    All Nikon lenses with the designation DX (except for the 10.5mm fisheye)
    All Nikon lenses with the designation AF-s
When it comes to third party lenses, Sigma, Tamron and Tokina, it becomes more difficult to find out which lens will, and which lens won't autofocus. Sigma does have the HSM (Hypersonic motor) which is similar to Nikon's SWM (Silent wave motor - designated by AF-s in the lens name). But apart from the HSM featured lenses, you will have to look at the product descriptions and look if it says anywhere that it has a built-in motor in the Nikon version of the lens.
Tamron has more lenses like that (only built-in motor no designation), but you can see if the lens has a built-in motor if the productnumber has the addition of -II, for instance: Model A17NII for the AF 70-300mm f/4-5.6 Di LD Macro 1:2.
Tokina
Tokina has only one lens at the moment that will autofocus on these bodies, the super wide-angle AF 12-24mm f/4.0 PRO DX-II, make sure it has the -II added to the name when buying, or look for the red stripe on the badge.
Tamron
These are the available Tamrons, according to Tamron Europe.
Di II lenses first (optimized for DX format) that have a built-in motor from release:
SP AF 10-24mm f/3.5-4.5
SP AF 17-50mm f2.8 VC
AF 18-270mm f/3.5-6.3 VC
SP AF 60mm f/2.0 macro 1:1
Look out with these:
SP AF 17-50mm f/2.8, look for product number A16NII
AF 18-200mm f/3.5-6.3, look for product number A14NII
AF 18-250mm f/3.5-6.3, look for product number A18NII
The AF 55-200mm f/4-5.6 has never gotten a built-in motor!
Now onto the Di lenses (Full frame/ FX compatible) that have a built-in motor from release:
AF 28-300mm f/3.5-6.3 VC
SP AF 70-200mm f/2.8
SP AF 28-75mm f/2.8, look for product number A09NII
AF 70-300mm f/4-5.6, look for product number A17NII
SP AF 90mm f/2.8 macro 1:1, look for product number A272NII
The AF 28-200mm f/3.8-5.6, AF 28-300mm f/3.5-6.3, SP AF 200-500mm f/5-6.3 and SP AF 180mm f/3.5 macro 1:1 have never gotten a built-in motor!
Sigma
And now concluding with the Sigmas. Same as with the Tamrons, I will use the European (Benelux) site for my information.
Lenses with HSM that are DC (optimized for DX):
EX AF 4.5mm f/2.8 HSM circular fisheye
EX AF 10mm f/2.8 HSM diagonal fisheye
EX AF 10-20mm f/4-5.6 HSM
EX AF 10-20mm f/3.5 HSM
AF 17-70mm f/2.8-4 OS HSM
AF 17-70mm f/2.8-4.5 HSM
EX AF 18-50mm f/2.8 HSM
AF 18-50mm f/2.8-4.5 OS HSM
AF 18-125mm f/3.8-5.6 OS HSM
AF 18-250mm f/3.5-6.3 OS HSM
EX AF 30mm f/1.4 HSM
EX AF 50-150mm f/2.8 II HSM
AF 50-200mm f/4-5.6 OS HSM
The AF 18-50mm f/3.5-5.6, AF 18-200mm f/3.5-6.3 have a built-in motor.
Lenses with HSM that are DG (Full frame/ FX compatible):
EX AF 12-24mm f/4.5-5.6 HSM
EX AF 24-70mm f/2.8 HSM
EX AF 50mm f/1.4 HSM
EX AF 50-500mm f/4-6.3 HSM
EX AF 70-200mm f/2.8 HSM
EX AF 100-300mm f/4.0 HSM
EX AF 120-300mm f/2.8 HSM
AF 120-400mm f/4.5-5.6 OS HSM
AF 150-500mm f/5-6.3 OS HSM
EX AF 300mm F/2.8 HSM
EX AF 300mm-800 F/5.6 HSM
EX AF 500mm F/4.5 HSM
EX AF 800mm F/5.6 HSM
EX AF 200-500mm F/2.8 HSM (Built like a tank, has it's own battery for AF :-P)
EX AF 150mm f/2.8 HSM macro 1:1
EX AF 180mm f/3.5 HSM macro 1:1
The AF 70-300mm f/4-5.6, AF 70-300mm f/4-5.6 APO, AF 70-300mm f/4-5.6 OS have a built-in motor.
The following lenses have no motor, they are all DG!
EX AF 8mm f/3.5 circular fisheye, EX AF 15mm f/2.8 diagonal fisheye, EX AF 20mm f/1.8, EX AF 24mm f/1.8, EX AF 24-60mm f/2.8, EX AF 24-70mm f/2.8, EX AF 28mm f/1.8, EX AF 28-70mm f/2.8, AF 28-70mm f/2.8-4, AF 28-300mm f/3.5-6.3, EX AF 50mm f/2.8 macro 1:1, EX AF 70mm f/2.8 macro 1:1, EX AF 105mm f/2.8 macro 1:1
I hope that at least the basics are clear, and that you feel inspired to invest the matter yourself more, now you have some basics :-)
- Wout -
