It is currently Sat May 25, 2013 9:12 pm
PostPosted: Sun Nov 04, 2007 11:22 am
I'm telling you guys I'm new to this DSLR thingeee and it's a fun challenge at times it's driving me nuts like right now.
Here's my problem
My problem is I took photos from a party earlier today and the camera was set to NEF Raw (I forgot that i had the setting change) But now I can't view it on my computer. what do I do... waaahhhhhhhhhhhhhhhhhhhhhhhh!!!
hahaha... seriously whaaatttt....
PostPosted: Sun Nov 04, 2007 11:47 am
There are number of free programs out there which should do the job (but as I don't have a Nikon I can't test this properly).
I use IrfanView to browse images (it can also do a bit of editing as well as conversion) and it advertises NEF compatibility. It is available here and don't forget to download and install the plug-ins available here.
EDIT: I have just tested IrfanView and it understands D80 NEF files. You can set up a Windows file association. If you want to use the File/Open menu then you need to select "DCR/DNG/EFF/MRW/NEF/ORF/PEF/RAF/SRF/X3F - Digital Camera RAW Format" in the "Files of type" listbox before you can actually see the NEF files listed. They aren't there when you select "All supported Graphics files" in that listbox which appears to be a bug. Once open you can convert them to JPEGs as you desire.
FastStone Image Viewer is apparently another option if you don't like IrfanView.
