It is currently Sun May 26, 2013 3:18 am
PostPosted: Wed Aug 22, 2007 11:55 pm
With common rechargeable batteries, it's best to wait before they fully lose their charge before recharging. If not, an electrical effect known as "memory" will lower they capacity (how much charge they will accept next time) and expected life (how many recharging cycles they will last).
What I'd like to ask is if this is a problem with the battery provided with the D40, named EN-EL9.
That is to say, in order to keep my EN-EL9 battery at top performance and to make it last more years, should I avoid recharging it before it goes flat?
Nikon D90 + MB-D80 + SB-600 + AF-S VR 18-200mm f/3.5-5.6 + AF-S 35mm f/1.8 + AF 85mm f/1.8 | My photos on Flickr.
PostPosted: Thu Aug 23, 2007 1:09 am
From what I know, Lithium-ion rechargeable batteries do not suffer from any memory effect. This was a problem with older NiCd rechargeables.
Darrin
Nikon D40 | Nikkor 18-55 VR | Nikkor 55-200 VR | Voigtländer Ultron 40mm SL-II | Nikon Speedlight SB-400
PostPosted: Thu Aug 23, 2007 1:52 am
That's right - all batteries have a memory effect to some degree, but apparently Lithium Ion suffers the least in this regard, so you should be safe to recharge before fully discharging... the really bad ones were NiCads, and to a lesser extent NiMHs.
That said, I still prefer to completely discharge any battery before recharging, but that's just me!
