It is currently Sat Jan 21, 2017 6:20 pm
PostPosted: Wed Jul 24, 2013 12:23 pm
I have 2 16 inch soft boxes with 105 watt compact florescent bulbs. I am thinking this is about 1000 watts combined.
It doesn't seem to give me enough light for my macro/portrait shots.
How would I determine what I need to get enough light?
PostPosted: Fri Jul 26, 2013 11:49 am
How close to the subject are you positioning the softboxes?
Rollei 35S
MY FLICKR!
PostPosted: Fri Jul 26, 2013 12:08 pm
Less than 12 inches. I have one point down @ 45 degrees on the left and one parallel pointing directly at the subject.
I take pictures of 1/25 scale cars and their components like engines etc.
PostPosted: Tue Oct 21, 2014 9:35 am
I have 2 16 inch soft boxes with 105 watt compact florescent bulbs. I am thinking this is about 1000 watts combined. :roll:
You can easily check out our9L0-412 real questions which prepares you EMC You can also get Harvard University real passguide wikipedia the quality examsheets.com Lyndon State College
PostPosted: Tue Oct 28, 2014 3:37 pm
Thanks how many bulbs are in each unit?
PostPosted: Thu Oct 30, 2014 1:17 am
You could get a light meter (which usually measure in lumens/lux, BTW, not watts).
Or you could just take a picture and see how many stops you are underexposed. (Keeping in mind that each stop under means you need to double the amount of light(s).)
Or since you're shooting static subjects with a constant light source*, you could just use a longer shutter speed.
* P.S. although, for macro photography, you generally want to use flashes/strobes, not CFLs.
PostPosted: Thu Oct 30, 2014 2:19 am
Thanks I will try that.
PostPosted: Thu Oct 30, 2014 3:53 pm
Shooting at what ISO?
Whatever the ISO, double it, then double it again - hey presto - 4 times as much effective light
