It is currently Sun May 26, 2013 4:51 am
PostPosted: Sat Aug 20, 2011 3:25 pm
I'm after something that will trigger a flash on movement. For example, if a light beam is broken. Not sure what they're called so I've had some search fail so far only turning up one expensive unit on ebay. The common cheap sound sensitive ones aren't appropriate for my application, although at worst I could modify one myself. Any suggestions?
PostPosted: Sat Aug 20, 2011 11:58 pm
No , but I would be interested in the result.
PostPosted: Sun Aug 21, 2011 12:53 am
Magic Lantern has movement sensor options
And its free
PostPosted: Sun Aug 21, 2011 8:26 am
Magic Lantern is totally the wrong application. I'm looking for something stand alone to trigger an external flash.
For example, here is one such unit on ebay, of which there are some more like it but they're all pretty expensive. For sound only, there's this one which is a lot cheaper. Was kinda hoping there's a light sensing one which was cheaper too...
I've got the electronics know how to build my own, but not the time! As a middle ground I've been thinking about getting the cheap sound one and modifying it myself which is a smaller job than building one ground up.
PostPosted: Sun Aug 21, 2011 8:38 am
The one listed on e-bay is also listed e-bay here as coming from Greece. Maybe send an e-mail and see if something can be build?
http://www.ebay.com.au/itm/Micro-Sound- ... 2a134b5b97
have a look at Stopshot
http://www.cognisys-inc.com/stopshot/stopshot.php
while googling came across this.
Worth a look
http://www.wired.com/wiredscience/2010/ ... ewall=true
PostPosted: Sun Aug 21, 2011 9:01 am
I got a feeling I need to adjust my value expectations here :D I like the article, but "hundreds of dollars" was proposed as the cheaper end and I'm looking to get an order of magnitude below that...
I'd have no hesitation on buying a more expensive unit if I know I'd use it more often, but my application here is more one off so I'm hesitant to do so...
