It is currently Sun May 19, 2013 7:14 pm
PostPosted: Sat Aug 13, 2011 11:31 am
I just wanted to ask if i need a more powerful flash from a particular direction will putting another strobe in the same settings right next to each other give twice the output in terms of exposure ? Or though it mathematically sounds right it doesnt work that way in reality ?
PostPosted: Sat Aug 13, 2011 1:44 pm
The best way to understand this is to think of light as small particles (photons). Now if you fire your flash at a subject a certain amount of all the photons your flash emits are going to hit it. Placing a flash with the exact same output right next to the first one will therefore double the amount of particles. Double the amount of light means a gain of one stop (+1 EV).
Therefore two equal flashes at half power will produce about the same amount of light as one of those flashes at full power. The benefit will be to have a shorter flash duration and recycle time plus if your flashes run on batteries you will get more flashes out of them (unless they are both using the same battery pack).
PostPosted: Sat Aug 13, 2011 4:37 pm
Good, so the math behind it works in real life as well. So when i need a blast during a sunny day ill pool 3-4 four flashes together to get a more powerful blast.
