It is currently Thu May 23, 2013 4:10 am
PostPosted: Sun Mar 13, 2011 8:58 pm
hi guys just got a yongnuo yn467 speedlite, it was cheap at only £60 new, and its better than the on camera flash, got to start some were , can anyone help when i try to use slave mode i cant seem to stop the on camera flash going of, i have a D80,Ive gone to the custom settings built in flash, commander mode, in the built in flash i change it to dash line, and Chanel 3 . it worked OK before but i think Ive change something.
any help or suggestions would be great :?
Nikon D80
18-70mm
70 - 210 D
PostPosted: Mon Mar 14, 2011 1:57 am
The YN 467 is not CLS-compatible. This means that the slave mode needs a powerful light source to trigger the flash, so with your current set-up you are still stuck with the built-in flash. The only solution that I can think of (without having to buy anything else) is using the built-in flash at a low power setting and using a relatively small aperture, like f8 or f11. This way, the built-in flash will still trigger the YN467 but will have little to no effect in the lighting. Set your built-in flash to manual mode 1/128 power and the flash to S1 slave mode. As an alternative, you can buy a set of radio-triggers. There are really cheap models like the RF-602 or cactus triggers.
Also, as a side note; a commander flash will always fire even when the power is set to (--) because the system needs to send TTL information through very short flash pulses, which are usually called TTL pre-flashes.
 Post subject: cheers
PostPosted: Sun Mar 20, 2011 9:17 am
thanks will give that a go
Nikon D80
18-70mm
70 - 210 D
