It is currently Tue May 21, 2013 6:21 pm
 Post subject: Flash Issue
PostPosted: Tue Mar 08, 2011 5:22 pm
I have a Canon and a blanking plate in the hot shoe.
The camera thinks that there is a flash present, and therefore refuses to fire the pop up flash.
Nikon come supplied with a blank anyway and I have not heard owners complaining that theirs will not fire.
Is there a way around this?
Canon EOS 500D
PostPosted: Mon Mar 21, 2011 9:46 pm
Try removing the blanking plate.
On Canon, in order for the camera to detect there is an external flash, and therefore disable the pop-up flash, there is a little metal strip where you slide the flash in. If it is not up, then the pop-up flash will be disabled.
Canon Rebel XTi, BG-E3 Grip
Sigma 150mm F2.8 EX Macro
Canon 430EX II
PostPosted: Mon Mar 21, 2011 11:28 pm
Hi,
Yes I am finding that I have to remove the plate out.
Are you suggesting that I remove the metal strip?
Canon EOS 500D
PostPosted: Tue Mar 22, 2011 12:53 am
I am not advising that.
This is the only way the camera can tell if it has an external flash. Tampering with this will make the pop-up come up even when you have an external flash.
This is the cause of your issue though.
Personally, I prefer an external flash over the pop-up one.
Canon 430EX II
PostPosted: Tue Mar 22, 2011 2:49 pm
The pop up one works sufficiently for what I use it for.
It is funny that Nikon users aren't affected by it though.
Canon EOS 500D
