It is currently Sun Jan 22, 2017 12:27 pm
PostPosted: Sat Aug 14, 2010 6:48 am
Hello all,
I was looking for help as to flash diffuser for nikon-d90 pop up flash.
I dont use flash enough to warrent spending hundreds of dollars on a sb600 800 or 900. So I was wondering which diffuser will be the best to use.
PostPosted: Mon Aug 16, 2010 9:33 am
Can't go wrong with a post-it note stuck to the front of the camera. If you need a bit more professional looking thing, look on ebay, im sure there will be something on there for a few $$
PostPosted: Mon Aug 16, 2010 10:27 pm
Hi David,
You might consider http://lightscoop.com/ as well. It is one way of diffusing the light and also get you better directionality on the light (i.e. not head-on).
Might I suggest you have a look at the SB400 as an option too? It recycles faster than any of the other SB-flashes, is cheaper and can be tilted in one dimension. I use this very inexpensive flash for daytime fill-light quite often, instead of my bulky SB-600.
Cheers :-)
PostPosted: Tue Aug 24, 2010 3:48 am
Gary Fong makes a product called the Puffer. $20 usd
http://www.garyfongestore.com/featured-products/puffer-pop-up-flash-diffuser.html
Truth be told, if you can find yourself a hot shoe flash, you'd be a lot farther ahead. Even if it's a third party flash, you can get them on e-bay dirt cheap.
PostPosted: Tue Aug 24, 2010 9:19 am
Just fit something white/translucent to your flash, and make sure the light spread is even. Me and Bjorn used white Canon bags over our flashes at an event. Worked well.
PostPosted: Tue Aug 24, 2010 10:11 am
The LumiQuest Soft Screen is a flash diffuser designed to fit most digital and film SLR pop-up flashes, just do a sardh sure you will find it
Alan
D4 & D700
http://www.alanwilliamsphotography.co.uk
BLOG: http://www.ayrshireweddingphotographer.org
