It is currently Mon May 20, 2013 9:27 pm
PostPosted: Fri Jun 04, 2010 1:14 pm
I've got my D90 setup to do this. I always bounce the flash when walls or ceilings or even floors are available and I use a little bounce card when it isn't.
I'm not sure what mode to use on the camera when doing rear curtain sync. What I think is the obvious thing to do is to have the lowest aperture because by using a slow shutter speed and then flash at the end, you want the subject to stand out. So I use aperture priority. Is this what others do?
I shoot RAW only and never ever use P or M, only shutter or aperture priorities.
Also, what about the flash mode. TTL? I've found that it doesn't recycle very quickly. Should I power it down a bit?
Cheers,
Matt
PostPosted: Fri Jun 04, 2010 7:48 pm
Open up your aperture as much as possible, and perhaps bump your ISO to 400 to save your batteries :)
PostPosted: Mon Jun 07, 2010 12:45 pm
Cheers for your reply Citruspers.
