It is currently Sun May 26, 2013 7:11 am
PostPosted: Wed Mar 03, 2010 9:07 am
hi,
i would like to know if one flash trigger mounted will fire several flashes simultaneously?
like CTR-301P RF Flash Trigger plus four Yongnuo-460 flashes placed in different areas?
Don't have job, Im finding one now for living >.<
PostPosted: Wed Mar 03, 2010 2:37 pm
if you have multiple receivers, than yes. depends on the product quality of course..
Journey of light - my blog!
www.anelfoto.blogspot.com
PostPosted: Wed Mar 03, 2010 5:39 pm
As long as they are all on the same channel then they will all fire.
Canon EOS 40D, EF-S 17-85mm f/4-5.6 IS USM, 50mm f/1.8 II, Tamron 90mm f/2.8 macro, EF 70-300mm F/4-5.6, Lensbaby Composer, Canon 430EX II, Giottos MTL 9351B tripod with 3-way head.
http://www.flickr.com/photos/i_gilmour/sets
PostPosted: Mon Apr 26, 2010 1:16 am
This depends on the settings that you select. I know with Canon's wireless system, you can have flash groups.
If you have your receiving triggers all on the same channel, then they will fire, as mentioned above.
Canon EOS 500D
