It is currently Mon May 20, 2013 11:31 am
PostPosted: Tue Aug 12, 2008 2:58 pm
Made with the Olympus E-510 and the 14-54 2.8-3.5
Enjoy:
Olympus E-30, ZD 9-18mm 4.0-5.6, ZD 50mm Makro 2.0, ZD 14-54mm 2.8-3.5, ZD 70-300 4.0-5.6
Light travel equipment:
Olympus EP-2, µZD 14-42mm , Panasonic 20mm 1.7 pancake.
Cullmann Trento IT Daypack
PostPosted: Wed Aug 27, 2008 1:01 am
Mmm, nice colours. I like the slightly off-centre position you shot it from. Unfortunately the foliage at the bottom, while quite subtle, detracts from the image somewhat as it doesn't fit in with the rest of it.
Did you do any post processing?
PostPosted: Wed Aug 27, 2008 10:49 am
I like it but maybe you should try it with a bit more contrast. And perhaps a little more saturation too. But you'll want to be careful with the saturation or make it really strong but that would simply create a different kind of photo. Which may be quite nice too.
Ben
PostPosted: Wed Aug 27, 2008 1:44 pm
I like the colors!! I don't know if you could have but I would like to see the same photo with the sunrise or sunset! That would make some really nice colors. Then again it might make the photo just like someone elses! I see alot of photos that do that so maybe the best thing is that you keep it as is! If you can I would like to see a photo of the same thing but at a time of sunset or sunrise so that I can see which is better! Thats if you can of couse!
P.S. Good shot!
