It is currently Mon May 20, 2013 2:15 am
PostPosted: Fri Nov 09, 2012 7:51 pm
Damn - here's me using 2008 camera technology (the Nikon D700)
A 4 shot panorama here gives me a 50MP image, so slightly more detail then a D800. A 35mm lens at f8 over this panorama range gives me around 17mm equivalent field of view on 35mm full frame, as well as plenty of depth of field.
Here's my final picture post on Camera Labs - thanks for all the good times and good luck to everyone in the future. Keep in touch if you'd like through my website (www.philpage.zenfolio.com)
The 50% original sized image:
http://philpage.zenfolio.com/img/s1/v56/p1254701498.jpg
And the smaller version to post on here:
PostPosted: Fri Nov 09, 2012 9:28 pm
Nice shot! :D
PostPosted: Sat Nov 10, 2012 6:12 pm
Not a bad way to end Phil - and I won't be pixel- or any other peeping! It sounds final this time so I'll say "thank you" for the amazing range of work that you've posted here. It was the results that you obtained with the D700 that made me move to FF myself, as you might have guessed from my questions and comments. This pic is yet another example.
It was going to be a D700 for me or a longer save-up for a Leica. The D600 coming along seemed perfect, giving the flexibility of Nikon's lens range while being a smaller package than the D700. I'll traipse along to your site from time to time and let you know how this oldster gets on with newer technology. If I begin to get anything like the results you do after only a few years I'll be well pleased. Good luck yourself.
And if you have time and see this, send me a PM about whether you clean your sensor yourself (other than using a blower).
PostPosted: Sat Nov 10, 2012 9:35 pm
Yet another nice one there Phil.
Always admired your work, especially the b&w. Good luck and I must keep an eye on your website.
Dent, Arthur Dent.
Pentax k-30 and k-x with DAL 18-55mm and DAL 55-300mm, Tamron 18-50mm and Camera Labs Straps.
