It is currently Thu May 23, 2013 10:37 pm
PostPosted: Mon Jan 09, 2012 9:55 pm
So I took this picture of Tower Bridge in London today, and after I transfered the photos to my computer, I noticed a slight fuzziness to the photo. I noticed this in both the RAW and JPEG files. The picture just doesn't seem clear. Could it be ISO noise? I only had it set at 800, so I don't think it's that.
Looking at the picture at full zoom through the link makes it more noticeable
PostPosted: Mon Jan 09, 2012 10:01 pm
Even at the slightly bigger level it isn't clear, but looking at the exif, the aperture was at f/22 which is into the diffraction softening zone. Unless you have a good reason to use it for some other reason, then try around f/8. That would also let you use a lower ISO setting too.
There may be other reasons too, but we'd ideally need a full size image to guess at that.
PostPosted: Mon Jan 09, 2012 10:04 pm
Know the best way to get that to you guys?
PostPosted: Thu Jan 12, 2012 12:57 pm
You could try this service; http://www.filedropper.com
It's limited to 30-days on the server I believe.[/url]
