It is currently Thu May 23, 2013 3:31 pm
 Post subject: Wafi Mall exteriors
PostPosted: Thu Jun 02, 2011 1:26 pm
I had an hour to kill the other morning, so popped into Wafi Mall to take a few shots. It was a little hot at 45c (112f) but I thought I'd try out my 85mm f1.4 with a ND filter (3 stop) to learn a bit about the lens.
Here are a few shots from around the outside of the mall:
1. @ f2
2. @ f2
3. @ f1.8
4. @ f1.4
5. @ f2.8
6. @ f1.4
7. @ f2
8. @ f2
9. @ f3.2
PostPosted: Mon Jul 04, 2011 7:02 am
And again - 160+ views and no comments.
Clearly something must be wrong, so please furnish me with some c&c
PostPosted: Mon Jul 04, 2011 9:48 am
Very interesting shots, I especially like 4. and 8.
The third one is almost too simetric, very nicely done.
I'm new to photography, I assume you had very high shutter speeds in these shots, as it was pretty bright and you used low f-numbers, is that correct?
PostPosted: Mon Jul 04, 2011 9:59 am
Thanks khalismur - I've found like in this section of the forum!
I was trying out a new lens, and trying out for sharpness and quality of background blur, so I was shooting close to wide open (low f-numbers).
As it was very bright this required a Neutral Density filter to let less light in as otherwise 1/8000th second would not have been quick enough to expose the images properly.
PostPosted: Mon Jul 04, 2011 1:23 pm
I see, you used a ND filter (now I know what you meant, hehehe).
Dubai is charming, I've seen other pics from you too in the past. Hope to go visit the country soon. Will surely buy a ND filter by then :P
PostPosted: Mon Jul 04, 2011 4:42 pm
ND isn't really required, just if you're using a shallow depth of field - f4 or greater means I can get away without one generally. Give me Switzerland and proper scenery over Dubai anytime!!!
PostPosted: Mon Jul 04, 2011 4:58 pm
Sometimes it's actually hard to decide which is the subject. Hehe kidding. :lol:
