It is currently Fri May 24, 2013 8:17 am
PostPosted: Sun Nov 23, 2008 8:31 pm
Sorry for the vague description, took this in a monastery on a hilltop. For some reason the picture does not pop and looks decidely normal. What could I have done differently?
Conditions: Sunny, indoors, took photo from in the shade
Settings: No flash, Indoor preset white balance
PostPosted: Sun Nov 23, 2008 9:50 pm
Try different angles? Try changing to black and white, even get down at a low angle.
These might make a difference?
Ed
Saving for: -
PostPosted: Mon Nov 24, 2008 7:38 am
the problem I see, is that the whole scene lacks a bit of color :) though to make the most out of it I think an even wider angle and a perspective from a low angle would have been better.
Canon EOS 5D Mark II | Canon EF 35mm f/1.4L USM | Canon EF 85mm f/1.8 USM | Canon EF 135mm f/2L USM
...and a lot of lighting stuff. -> complete list of equipment
Website
Blog
PostPosted: Mon Nov 24, 2008 10:01 am
The colour is there but the light colours are too light and the dark colours too dark giving high contrast and low colour. I tweaked the histogram by applying "Midtone Compression" which shifts these very light and very dark colours more towards the middle. Because this also causes an overall loss of contrast I then increased contrast again.
Since there is no better way of showing you what I mean than, well... showing you what I mean I have posted the result here assuming you wouldn't mind. If you do it's easily removed.
This is a result of only adjusting relative lightness in the photo. No changes to colour settings like white balance, saturation or hue were made. Just the two I described above. I hope you like it.
Ben
PostPosted: Mon Nov 24, 2008 10:42 am
Like some of the others have said I might have tried a lower angle. Other than that I'm not quite sure.
PostPosted: Wed Nov 26, 2008 7:27 am
Nice edit Ben. I think what breaks the original photo is the "whiteness" of the scene. Sure, it could work in other scenes but in this case I think it makes it a little too clinical.
edit: In this instance though, instead of playing with midtones levels you could just bump the saturation and you'll get a similar result to what Ben got. Main difference is the histogram of the saturated image looks a bit more toothy. Just adding this here in case you don't have software that can modify midtones.
PhilipGoh.com
