It is currently Thu May 23, 2013 12:44 pm
PostPosted: Tue Oct 11, 2011 10:55 pm
tried my first low light candle scene. shot different exposures and apertures. on tripod and cable release. these are a couple best ones i was able to get out of about 40 or so i took! also as above got some lens flare. when i first took some i had a haze filter(cheap one) on the lens i forgot about (as it came with the lens and i had just left it on...) which made lens flare a lot worse. however... still have flare, maybe could of recomposed the shot at different angles? or would that not have made any difference? am sure theres more i can do to get better results. CC welcome!
take with sony a200 and minolta 50mm f1.7
well anyways here they are!
f2.8, 1.3sec, iso100. pp - levels, touch of saturation and contrast
f2.8, 1/2sec, iso 100, pp - as above
f1.7, 1/50sec, iso100, pp - as above
most of the pics were taken at f1.7 however not many of them came out that well. also used multi segment metering as i found this got the best results after trying centre weight and spot. it was all just a case of trial and error with different settings. but thats photography so i hear :lol:
Sigma 18-200mm f3.5-6.3
Minolta AF 50mm f1.7
http://www.flickr.com/photos/alan_parker/
PostPosted: Tue Oct 11, 2011 11:12 pm
yes theres no flare in the last one, which suggests to me it was probably caused by the angle/composition of the shot. i had a quick check of the other pics i had binned and did not get flare when shooting close/directly at the flame. like the 3rd pic. hmmm
i dont believe the aperture had much to do with this as there was still flare on the 1.7's when shot from certain angles.
