It is currently Wed May 22, 2013 5:00 pm
 Post subject: Tried some still life
PostPosted: Sun Dec 06, 2009 7:51 pm
Tried some still life, but when it comes out the camera it was not sharp at all, this is after using editing software to shapen it up a bit and I still think it could be better
I used PhotoScape and its not very good. My Photoshop 7.0 will not install into Windows vista
Canon 50D, EF-S 18-55mm f/3.5-5.6 IS, EF-S 55-250mm f/4-5.6 IS, EF 50mm f1.8, SlingShot 100,
MyFlickr
PostPosted: Sun Dec 06, 2009 9:27 pm
It looks like you have a very shallow DOF there. The Argentinian badge is out of focus, whereas the Hungarian one if the sharpest. It appears to me that the camera has focused on the bed stitching below the subject.
What settings did you use - it looks like a high ISO with some cropping, but perhaps your shutter speed was a little too slow?
PostPosted: Sun Dec 06, 2009 10:49 pm
ISO was 3200, f2.2 and shutter speed was 1/50
There was two AF points and that was below germany and next to france
MyFlickr
PostPosted: Mon Dec 07, 2009 5:02 am
I'm not a Canon user, but a shutter of 1/50 is perhaps a little slow for an EFL of 80mm (assuming you used that 50mm prime). I would try again in better light with shutter priority set to 100 and see if that improves sharpness.
Also, in challenging light, I sometimes find burst mode helps. If you shoot 3 images in burst, then the 2nd one isn't influenced by you pressing the shutter button.
Another option would be to try again with a tripod to rule out focusing problems (by you or the camera).
I'm having similar problems with soft images, but increasing the shutter speed or using a tripod doesn't seem to help me much - maybe it could help you though.
I started a thread regarding similar issues to yours: http://www.cameralabs.com/forum/viewtopic.php?t=18868
PostPosted: Sun Dec 27, 2009 6:37 pm
Set Down That Iso, About 200 Or 400 For Indoor Pictures
Canon Rebel XTI 400D
Canon EF-S 18-55mm
Rubber Lens Hood And UV Filter
Canon 200GD Camera Bag
