It is currently Tue Jan 24, 2017 5:36 am
 Post subject: Switching lens's
PostPosted: Wed Jun 11, 2008 2:34 pm
I'm after some tips on how to quickly and efficiently change lenses from a camera bag and how to reduce the likelihood of dust getting in while standing up and not having anything to put the bag on while im out shooting.
PostPosted: Wed Jun 11, 2008 3:26 pm
Try this:
1) Take out lens from lens case, if any.
2) Remove rear-element cap.
3) Detach mounted lens.
4) Mount next lens.
5) Place rear-element cap on lens you're not using.
6) Remove lens cap from the lens you're about to use. (optional)
7) Shut bag if it was opened. (optional)
If you're fast enough I'd say you could do this in under 10 seconds although don't rush through it. Should be faster with practice.
I saw an event photographer doing something similar to the above listed steps, except it was with a leg/belt-attached lens case. I forgot when was the 'keep-previous-lens' step though :lol:
Good luck finding your preferred method!
SnS 8)
PostPosted: Wed Jun 11, 2008 4:00 pm
thanks for the advice. The main problem I have is not having enough hands, I only have two! Having to hold the camera and the two lenses that I want to switch is difficult.
PostPosted: Thu Jun 12, 2008 3:49 am
The A100 comes with a neck strap right?
The method I mentioned only requires 2 hands at a time. Hold one lens and the camera. With practice you won't even need to hold the camera while mounting the lens(not recommended though). You could leave one lens in the bag while holding the next.
Ask if you have any doubts :)
SnS 8)
PostPosted: Sun Jun 15, 2008 5:41 pm
To minimize (if not prevent) dust infiltration, you may try detaching/mounting lenses while the camera is pointed downwards.
PostPosted: Sun Jun 15, 2008 5:46 pm
Here's my method:
1) Camera around neck, I let it go and leave it hanging.
2) Grab the lens, with the lens cap on.
3) Push the lens release button on the camera and twist the lens until it has reached the point of removal, but is still over the lens mount.
4) Using my pinky and ring finger on the hand that holds the new lens, I twist and remove the lens cap while dropping into my camera bag.
5) As I bring the new lens up to the camera, my left hand removes the old lens. In an instant, the lenses have changed.
6) Put the old lens cap on the removed lens, and stick it in my bag.
7) Take the picture :)
That's what I do... Most of the time I'm shooting.
PostPosted: Mon Jun 16, 2008 9:36 am
if you wanted to take your time looking through your bag you could put the lenses cap on the body temporarly.
I guess this is one of those things you find out for yourself and heavily depends on how dextrous you are and what your bag is like ... and also your location
PostPosted: Mon Jun 16, 2008 10:45 am
I change my lenses more or less like this guy:
http://www.youtube.com/watch?v=PiWctOW5p6A
I do try to do it with the camera pointed downwards.
quick
It took some exercise to do it quick and right, while I do not have very big hands.
not very practical with big lenses.
PostPosted: Mon Jun 16, 2008 11:00 am
thanks for that video, really helpfull.
PostPosted: Mon Jun 16, 2008 3:13 pm
this minimises the time taht the camera body is open but if you camera has a ust removal system on the sensore should you not be more worried about dust getting into the open lenses?
PostPosted: Mon Jun 16, 2008 4:05 pm
Dust removal systems are usually next to useless in my experience (except perhaps in Olympus cameras). Have a look at this dust test photo of my 40D. As you can see the anti-dust has had no affect at all and there are many more dust spots visible at 100%. So although it is necessary to ensure that the mount end of the lens is kept clean (I agree with you completely) it is equally important to protect the sensor.
PostPosted: Mon Jun 16, 2008 4:14 pm
how do you actually test how much dust is on the sensor?
PostPosted: Mon Jun 16, 2008 4:21 pm
Well it's not scientific or anything but all you do is take a picture of a white/gray surface and use a small aperture. The result is here. You can clearly see the dust spots all over the sensor. After cleaning the sensor take another picture of a sheet of paper to make sure it's all gone. Remember that I have used f/32 in the above shot to identify as much of the dust as possible. This much would rarely show up in real life as those apertures are best avoided because of softness caused by diffraction, but some was showing at around f/11.
