It is currently Sat May 25, 2013 2:46 am
 Post subject: about shutterspeed
PostPosted: Mon May 19, 2008 3:59 am
hi, just wanna ask what's 1/60 shutterspeed?
coz the camera i use has a max 4000 tv, and i can adjust it manually like to 3" or 0.5" when shooting at night like in your tutorial. im now studying your tutorial on " How to blur action shots for speed ". i just don't get the 1/60 shutterspeed. im new in photography. i dont know much with slr.
thanks a lot,
cheers!
PostPosted: Mon May 19, 2008 5:24 am
Hello jsonvega!
Welcome to the Camera Labs forums.
Shutter speed is measured in seconds, and it means how much time will the shutter be open for. The longer the shutter is open, the more light reaches the camera sensors, and the brighter the recorded image is. It also works vice versa.
1/60 means the shutter is open for 1 over sixtieth of a second, which is nearly 0.02 seconds.
The typical shutter speeds range from 1/4000th of a second to 30 seconds. Although on some cameras there is up to 1/8000 of a second, and Bulb mode meaning the shutter will be open for as long as the shutter release button is held.
In photography we usually measure any amount less than a second as a fraction, but 0.3"(double inverted commas denote seconds, not inches) and above and the camera will show it as decimals.
Please feel completely free to ask any question, and the friendly CL community will try its best to answer! :D
SnS 8)
P.S.: In Canon cameras, Shutter Priority mode is labelled Tv(and Aperture Priority is labelled Av), but on other brands it is normally labelled S(and A for Aperture Priority).
.: Sony DT 18-70mm :: Sony 75-300mm :: Tamron 90mm f/2.8 Macro 1:1 :: Minolta 24mm f/2.8 :: Sony 50mm f/1.8 :: Samyang 8mm f/3.5 fisheye :: SLIK Pro 330DX :: Manfrotto 496RC2 :.
my flickr
PostPosted: Mon May 19, 2008 6:15 am
i see, so 0.02 is actually 0.02"?
thanks for the information, I'll experiment on it! :D
