It is currently Sat May 25, 2013 12:30 am
 Post subject: Disney's Electric Parade
PostPosted: Sun Mar 16, 2008 3:06 am
Any suggestions on what setting I should use to shoot the Disney's Electric Parade? I have a Canon 40D kit. :?:
Canon 40D with battery grip, Canon Power Shot SD870 IS, Canon 28-135mm 3.5-5.6 IS USM, Canon 100-300mm USM, Canon 50mm f1.8II, Canon 430 Speed light with diffuser.
http://www.flickr.com/photos/jzabfc/
PostPosted: Sun Mar 16, 2008 7:00 am
Hi JZ Alba, welcome to the Cameralabs forums!
For the uninitiated here - including me! - tell us more about the conditions and content of the parade. Is it at night? Does it move quickly? Where will you be in relation to it, distance-wise?
PostPosted: Sun Mar 16, 2008 7:23 am
the event is at night. It is the light parade of disney's characters. It is a slow moving parade. The problem is that if I use flash, the magic of the night light parade is gone. I want to capture the very nice lights of it without any noise. By the way, distance would be 10-20 feet away.
PostPosted: Sun Mar 16, 2008 9:02 am
Weeeell, if you're eliminating the flash, both for effect and distance, then your only option is to either increase your ISO sensitivity (with the result of higher noise) and or use a lens with a bright aperture - ie small f-number.
A great investment for any Canon owner is a 50mm lens - they do three and the f1.4 in the middle is a great choice. It'll gather 16 times more light than a kit lens at f5.6, so allows you to shoot in low light without increasing your ISO too much. That said, you may still need to increase it a bit, say to 400 ISO.
See Canon's 50mm range.
PostPosted: Sun Mar 16, 2008 10:45 am
Thanks for the advise. I will start searching for a better lens as you mentioned. :D
PostPosted: Sun Mar 16, 2008 11:41 am
You'll also find that a monopod will help.
Nikonian
PostPosted: Sun Mar 16, 2008 10:41 pm
thanks. I have a tripod so I will bring it as well.
PostPosted: Sun Mar 16, 2008 10:47 pm
The tripod will help if you find yourself a good viewpoint and plan to stay there. However if you plan to move about, the added mobility that a monopod gives you is insurmountable.
Nikonian
PostPosted: Mon Mar 17, 2008 2:19 am
Thanks, I'll search for a resonable price monopod.
PostPosted: Mon Mar 17, 2008 3:46 am
what is your kit lens? do they have IS ? I also recommend 85mm f1/8 it is good for 15-20 ft range and good for close up too.
try to use iso 800 or below, and also use spot metering. point the AF to the
object of interest (face etc) to get accurate metering.
PostPosted: Mon Mar 17, 2008 8:14 am
You will be pleasantly surprised that even a Manfrotto monopod has a very nice price. that is unless you want a head on it. But for my purposes I just screw the camera directly on the single "leg", shoot only in landscape orientation and tilt back and forth to get the right angle. Might not fit your photographic task though...
PostPosted: Mon Mar 17, 2008 8:37 am
I have the canon 28-135mm IS f3.5-5.6. thanks for the advise.
PostPosted: Mon Mar 17, 2008 8:39 am
I will be in one spot only. Doesn't monopod also require to be steady when taking longer shutter speed? Monopod is great for daylight photography but nighttime is kinda hard especially on longer exposures. (I think)..... :?:
