It is currently Thu Jan 19, 2017 3:30 pm
PostPosted: Sun Jun 03, 2012 1:12 pm
hi, i'm new to the world of digital cameras, i have a passion to take good photos, i own a canon 60d with a 18mm to 55mm lens.i need some help on taking photos of lightning
thanks cheesy
PostPosted: Sun Jun 03, 2012 10:20 pm
Easiest way that I've found is the to set the camera to the following using the lens you've described (I'm assuming it's the kit lens)
f - 5.6 (or whatever the lowest setting is)
ISO - 100
Evaluative metering
Shutter Speed - usually 30 secs if at night
Good sturdy tripod
Most important bit of kit - a small black cloth (microfibre cleaning cloth is perfect, big enough to cover the front of your lens))
Set focus to infinity, switch to Manual Focus and make sure IS is switched off as well. Hit your shutter and wait for a strike. If it's a rather stormy night, this is where the cloth comes in - after capturing a couple of strikes, I'll carefully cover the lens to stop anymore light coming into it and wait until the shutter closes.
The above technique also works well for capturing fireworks where you don't want too many fireworks in the shot at one time.
Canon 5D MKIII, Canon 60D, 70-200 f2.8 L, 17-40 f4 L, 50 f1.8, 24-70 f2.8 L, 50 f1.4
http://www.flickr.com/photos/55078072@N06/
PostPosted: Sun Jun 03, 2012 11:44 pm
Great tip for the black cloth Chopper, I'll definitely give that a shot.
Cameras: Canon EOS 6D, Canon EOS Rebel T3i, Canon EOS Rebel T2i, Canon S90
Lenses: Tamron: SP 24-70mm F/2.8 Di VC USD, SP 70-300mm F/4-5.6 Di VC USD, Rokinon: 8mm Fisheye cine, Canon: EF-S 18-55mm f/3.5-5.6 IS Lens, 75-300mm f/4.0-5.6 III, and EF 50mm f/1.8 II
PostPosted: Mon Jun 04, 2012 11:20 am
Great tip! I haven't shot fireworks or lightning but I'll definitely bear that in mind if I do.
CSC: Canon EOS M3
PostPosted: Fri Apr 05, 2013 6:36 am
If you want to take impressive lightning photos then you should use a tripod and use remote shutter in order to take shots. You should set the shutter speed and aperture properly. Most importantly, you should frame the picture where most of the light occurs.
PostPosted: Fri Apr 05, 2013 6:48 am
I'm no expert photographer but setting your shutter speed and aperture properly is true of any photo you take....
CSC: Canon EOS M3
PostPosted: Mon May 20, 2013 7:10 am
As I know you should have a lightning trigger for taking shots. I'm into lightning photography and i read a review on gizmag about that device called Nero Trigger. It can be very helpful for images you want to capture. You should check it out.
PostPosted: Mon Oct 21, 2013 10:37 am
ou do not want the camera searching for focus when trying to take pictures of lightning - so you need to set it to infinity first. Any slightly out of focus shots of lightning are very noticeable with digital.
