I use a variable nd circular filter by marumi. It has 8 stops as you rotate it, ie it darkens as you rotate.
I have found that it works very well at 2, 4 and around 6 but struggles above 7 and close to 8.
I bought it to start learning about nd filters and whilst it s not as good as a true nd it's a good learning tool.
If you are looking at buying one filter them I would probably go for a 4. It really depends on when and how you are looking to use it though.
Got some of the gear but really still no idea...
