It is currently Sun Jan 22, 2017 2:07 am
 Post subject: brightness and exposure
PostPosted: Fri Oct 26, 2012 2:41 am
hai friends plz tell me in simple words whts the difference between brightness and exposure?
r they same?
if not whts the difference?
whts their effect in a pic?
PostPosted: Fri Oct 26, 2012 3:28 am
Let see if I can explain this right, still learning myself. It depends on the program your using so some of the terms I use below may not be the same for you.
Exposure is for the over-all picture. You adjust your exposure first to set your highlights. If you over shoot your exposure you can introduce noise into the shadows. Next your Brightness affects the mid-tones more, so if you get the highlights right with Exposure but the picture itself is still a little dark you go to your Brightness. Then you adjust your shadows or fill light in the really dark areas.
Hope that helps
Mike "The Squirrel"
