It is currently Tue May 21, 2013 5:12 am
PostPosted: Thu May 12, 2011 9:59 am
Ok, first off the following photo was done with a Point&Shoot on Auto
My plan is to return to the same spot this summer with my T2i and retake this pic again, what would you do to improve it.
My biggest concern is the huge block of light coming thru right in the middle of the pic. My desire would be to slow the shutter to get that nice look on the water but but don't see how I could with that area of light. What else would you or could you adjust to fix a mixed-lighting situation like this
Also, would you use a polarizing filter in this situations like this?
Mike "The Squirrel"
PostPosted: Thu May 12, 2011 11:51 am
!st thing would be to pick a less bright day, or a different time (sun & water don't generally work) Tripod & longer shutter speed would also help.
You could also BKT 3 shots & merge them to help with shadows etc.
Looks a lovely place & good POV on your shot.
PostPosted: Fri May 13, 2011 5:59 am
Thanks, I figured time of day would be an issue. Would a polarizing filter do anything for this or do you only use a polarizing filter when you are getting direct sky.
Mike "The Squirrel"
PostPosted: Fri May 13, 2011 12:09 pm
Polarizing filters can help with water refelction/glare on sunny days.
PostPosted: Fri May 13, 2011 7:18 pm
Return there on a cloudy day, maybe even after the rain if you wish to boost some more saturation. Add a polarizing filter to it to slow the shutter speed even more and reduce some of unwanted reflection and this will boost the saturation too. Try to do several different compositions, I would suggest to take the camera lower to the ground, but I can't say for sure because I am not aware of surrounding area that is not included in your shot.
PostPosted: Sat May 14, 2011 3:54 am
I agree - overcast or when there's even light in the scene.
I'd think about taking my tripod and setting up by where the branches are in the foreground, getting the camera really low by the water's edge. It might need a wide angle to capture the scene in portrait orientation, but stopped right down you'll get good depth of field.
Then I'd either go for a polariser or polariser and ND filter to get a long shutter and blur all the water.
PostPosted: Sun May 15, 2011 12:05 am
May I express a different opinion?
Why look for a more flat lighting?
I think it's nice as it is. It gives depth and drama to the scene. All the accents, that are now present, make the picture vibrant and pleasant.
And I wouldn't blur the water. Why turn it into something unreal. Nowadays everybody seem to blur the waterfall and turn it into the "dreamy" cliche. A waterfall is rather on the violent side than on the peaceful side of a landscape. Wholly water, as I call it, takes the punch out of a beautiful site, all th spray and foam so characteristic is gone and the glitter completely disappears. That's not water anymore.
But that's only my opinion.
Radu
Canon PowerShot S100
Canon580EXII
http://www.errre.net
PostPosted: Sun May 15, 2011 1:55 am
My personal preference is the same as Radu's, I try and capture the sparkle of water. It looks like the sun is directly overhead in this shot, perhaps a different time so the lighting is not so harsh on the top section of water. Still a good shot.
PostPosted: Tue May 17, 2011 2:38 am
Mike, the photo you took is very nicely composed.
A polarizer will not work on water like this waterfall. And if you go in the summer you will most likely not get the same water flow level, so go again soon while the ground is still purging its excess water.
I really like the sun striking the scene. I think you need to take a few shots changing the shutter speed to get the overexposed and underexposed scenes back into a manageable contrast range and then blend them together. A tripod would greatly help getting each of shots to blend together in proper registration.
PostPosted: Tue May 17, 2011 7:44 am
I really appreciate all the comments, you all have givin me some things to think about..Thanks!!
On doing the multiple exposures, is there a tool built into Photoshop CS5 or GIMP that will do the blend or is is something for me to play with, I have both. I'm very good with computers and graphics but just getting started on photo manipulation (besides cropping and resizing).
Mike "The Squirrel"
PostPosted: Tue May 17, 2011 2:27 pm
CS5 has an HDR function in it mike.
PostPosted: Wed May 18, 2011 7:15 am
Mike,
I actually did not mean HDR blending I simply meant manually blending several exposures, see youtube for relevant tutorials, such as this:
http://www.youtube.com/watch?v=KMBQUXYNqPs
PostPosted: Wed May 18, 2011 7:58 am
WOW that is so easy! Thanks!
Mike "The Squirrel"
