It is currently Tue Jan 17, 2017 4:57 am
PostPosted: Wed May 11, 2011 11:16 am
What is a 70-200mm on a cropped camera?
Canon EOS 500D
PostPosted: Wed May 11, 2011 12:14 pm
Still a 70-200mm. It never changed.
Unless you're talking about 35mm equivalent field of views, where you multiply both by 1.6x but that doesn't mean anything unless you have a reason for it to.
PostPosted: Wed May 11, 2011 1:15 pm
To add to what Popo said,
A 500D with a 70-200mm lens on it has the same field of view as a 5D with a 110-320mm lens on it.
However the depth of field is not the same. It gets complicated to explain, but basically there is always going to be more in focus on a the 500D
PostPosted: Wed May 11, 2011 2:09 pm
On a Canon, multiply by 1.6x for the crop factor of any lens. On a Nikon, Sony, or Pentax, multiply by 1.5x.
As others mentioned, it's not changing the actual focal length - it's basically 'cropping' the view. But the above will let you know what the equivalent view is on APS-C cameras for any lenses you attach.
Justin Miller
Galleries:
PostPosted: Tue May 17, 2011 9:10 pm
this will help you
www.usa.canon.com/app/pdf/lens/EFLensChart.pdf
it has all that numbers for fullframe, aps-c and aps-h, quite useful document.
I highly reccomend it!
basically, if that would be ef-s lens, it would have name like 110-320mm L ..., adn you will see further away than someone with FF sensor
Canon AT-1, 50mm FD F1.8
Canon A430,
PostPosted: Wed May 18, 2011 11:31 am
... "basically, if that would be ef-s lens, it would have name like 110-320mm L"
This is wrong and this mis-information is confusing people.
All lenses whether Canon EF, EF-s or Sigma/Tamron are marked with their actual focal lengths.
Rollei 35S
MY FLICKR!
